Support In Crawl Space - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-02-2015, 10:31 PM   #16
Rewards Points: 1,826
You said: "The utility room sags where the hot water heater and water softener sits."
Please clarify whether this means (1) that the floor joists are actually bent from the floor loads such that you can see they are bowed from the crawl space, or (2) the entire utility room has become lower at one end while the floor joists are still straight.
There's a big difference between 1 and 2.
ChuckF. is offline   Reply With Quote
Old 07-02-2015, 11:50 PM   #17
Rewards Points: 740
It is hard to tell. One joist has a vertical crack in it, and the other has a horizontal crack. It appears to be a josit problem. I jsut want to know if I can put down a cement pad on the ground or if I have to dig.
crescere is offline   Reply With Quote
Old 07-02-2015, 11:52 PM   #18
Rewards Points: 740
Originally Posted by jogr View Post
If its a nice flat surface you should be ok framing up and pouring concrete pads on the surface. The dimensions of the pads depends on the loads and number of posts.
Great thanks. It is a very tight crawl and digging a hole would be tough and time consuming. The surface seems okay to me.
Crawl Space Advice Perry401 General DIY Discussions 6 02-22-2014 03:23 PM
Main support beam in crawl space stadry Building & Construction 2 02-21-2014 08:35 AM
Crawl Space Insulation in NWT Canada too-cold Insulation 3 11-10-2012 03:11 PM
Vapor barrier issue between crawl space and conditioned basement gregsenne Insulation 3 10-12-2012 12:53 AM
Inadequate center support in tight crawl space 4just1don Building & Construction 5 09-28-2008 04:29 PM
