Sump Pump Water Lower Than Normal???? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-29-2009, 06:58 PM   #16
Concrete & Masonry
Rewards Points: 518
Originally Posted by itsreallyconc View Post
sonny, my eyes aren't that bad yet but i STILL don't ' see ' the float & we put in 5 zoeller m-53's a wk,,, htf jo could see it from HIS house's beyond me
I can't believe you can't see the stuck float! Better have those eyes checked!
I just made a few assumptions after reading the info given. I know how pumps are installed around here, & knew the tiny relief hole at the bottom only squirts like that continuously if the pump is stuck on.
jomama45 is offline   Reply With Quote
Old 12-02-2009, 03:59 AM   #17
Rewards Points: 3,614
buying another dz m-53's today,,, will post pics,,, so chuck you, farley
Old 12-04-2009, 08:44 PM   #18
Rewards Points: 150
ok guys, well been a week or so and pump been ok besides that the float got stuck up again today, i dont know why the float is staying up, but once i unplug it then plug it back in, it seems fine.
this is the pump i have
liberty pumps, model 257, 5.2 amps, 1/3 HP, 115 volts, 60 hz, date on it is 2007 may.
now i have no battery back up. I was thinking about replacing the pump because of the float getting stuck again. i was looking at libertypumps webpage and checking out the same pump. i know that the pump float gets stuck so why get the same one? well i figured it would be a easy replacement being that it has the same outlet and all.
what type do you recommend? how can i get the battery backup.
fabian is offline   Reply With Quote
Old 12-05-2009, 05:26 AM   #19
damn - that's NOT a zoeller in your pit ? ? ? never heard of your brand,,, we use zoeller ( mostly m53 1/3hp ),,, when you see the 12v dc's output & power range, you may change your mind,,, imn-s-hfo, zoeller makes the best bbu, too !
we buy from ferguson,,, don't forget ck valve replacement, too
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Basement sump pumps, 1 runs more than other cjdock Building & Construction 3 11-02-2009 06:28 AM
Sump pump issues GeorgeHuhges Plumbing 3 10-19-2009 02:43 PM
