Suggestions - Mounting TV (Metal Studs) - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 05:23 PM   #16
retired union carpenter
Rewards Points: 278
hi handyman, I'm new to this site. but I'd did drywall and metal studs most all my working life until 19 years ago I suffered a massive stroke, and I've mounted many, many TVs on hospital/office room walls. even if your metal studs are the simple 25 gauge studs? 2 quarter in toggle bolts will hold your TV. of course when we built the walls we put 2X10 backing in the walls, but pre-existing walls toggle bolts will hold up just fine. try to get as close to the center of the studs as you can, a good stud finder should help. remember metal studs normally aren't as wide as wood studs, meaning instead of an inch and a half wooden stud a metal one is only an inch and a quarter, maybe 3/8? can't remember. tighten the toggle bolts snugly then maybe another 1/2-3/4 turn. much more will break the paper on the drywall, broken paper is harder to fix than if it has been cut!
good luck
coupe
coupe is offline   Reply With Quote
Old 11-27-2011, 02:36 PM   #17
Electrician
if the bracket is less than 16" wide its only required to be centered mounted to one stud. So center the bracket on the stud and to go the extra mile(not required) put four toggles in the corners. just that simple.
StackEz is offline   Reply With Quote
mounting light to metal ceiling stud? mpelleg459 Remodeling 2 04-24-2011 08:54 AM
heavy shelves, metal studs... themikeindy Carpentry 2 03-28-2011 10:36 AM
Using metal studs with a suspending ceiling MinerReb Remodeling 7 04-02-2010 06:57 PM
metal studs to build up attic floor Airborne180 Carpentry 6 12-13-2006 05:02 PM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 07:17 PM
