Suggestions On Deck For Swingset - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-25-2010, 11:04 PM   #1
Rewards Points: 159
Suggestions on deck for swingset
I started a rather large swing set last fall.
I have the swing section done, I want to jump and get the deck section done this spring.
So I have a 16'x16' deck section ( I said it was big!)
When I left off last fall...
Every 8 foot I have a 4x6 buried 4 foot in cement.
I then went around the 16' perimeter with 2x6 carriage bolted through the 4x6's
In the spring I was planning on laying 16 foot 4x6's every 16 inches
I am not really how to tie these into the existing wood I have.
theedudenator is offline   Reply With Quote
Old 01-25-2010, 11:59 PM   #2
jlhaslip's Avatar
Rewards Points: 708
notch them about 1 inch to sit on the 2x6 and use 8" panel screws (pre-drill them).
got a picture?
jlhaslip is offline   Reply With Quote
Old 01-26-2010, 11:07 AM   #3
Rewards Points: 5,348
If this is an unsupported span of 16', then 2x6's are too small. If you could install a mid span support, that would work.
Ron
Old 01-26-2010, 11:33 AM   #4
jlhaslip's Avatar
Rewards Points: 708
4 x 6's are mentioned for the 16 ft span
Old 01-26-2010, 12:38 PM   #5
The 4x6's are vertical posts(" Every 8 foot I have a 4x6 buried 4 foot in cement.") and the implication I read was that they were only around the perimeter.
Ron
Old 01-26-2010, 01:33 PM   #6
Rewards Points: 159
The 4x6" supports are 8 foot in all directions.
So I do have midspan support.
The longest span in any direction without support is 8'.
I was planning on just putting 2x6's in with joist hangers.
But this would then mean I have a few 2x6's that are unsupported.
I think I need to get some photos...
Old 03-26-2010, 11:54 PM   #7
Rewards Points: 159
I sketched something up now.
The posts are 4x6 cemented into the ground.
8 foot apart. The total square is 16 foot X 16 foot
The bottom boards are 2x6 that are lag bolted to the 4x6
I thought I could just add additional 2x6 on 16" centers to start the deck.
But I think I need another layer of 2x6's?
Any suggestions?
The image is what actually is built already
Old 03-27-2010, 08:12 AM   #8
Rewards Points: 159
The 2x6's are actually drilled and carriage bolted. Not lag bolted.
Old 03-27-2010, 09:36 AM   #9
Is this attached to the house or anything else ?
Are you now putting a roof on ?
Or will people be walking on top of this ?
Old 03-27-2010, 10:26 AM   #10
Rewards Points: 159
This is a playground.
There is an a-frame swing set attached to one side of it.
There will be the floor, a second level with floor (for the slides and stuff)
And a simple roof
Old 03-27-2010, 10:41 AM   #11
You would need to put beams across to support the floor joists for 2nd floor
Then the floor joists would sit on top of the beams
Best way is to notch the 4x6 posts
Not sure what size the beams need to be
Old 03-27-2010, 11:15 AM   #12
Rewards Points: 159
I understand that.
I am wondering about the 1st floor now.
Do I use the existing 2x6 for beams? Or do I just start putting 2x6' between the existing. But then I would have 16 foot spans of un-supported 2x6's
Old 03-27-2010, 11:41 AM   #13
Is this directly on the ground ?
I put old cement patio block under my free standing deck for support
I only had a 12' span
If you have support on the outer edges & under the middle wood
Then put in 8' 2x6's between those as the joists
IE they would be running right to left in the pic
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Deck Suggestions nursenuttree Building & Construction 2 06-24-2009 03:28 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Enlosing underneath the deck? Need suggestions and any help you can give. KoolAid Carpentry 3 04-17-2008 07:05 AM
