Subfloor With Small Dip - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-23-2019, 03:56 PM   #1
Rewards Points: 32
Subfloor with small dip
The floor of my house has now a noticeable small dip. I went into the crawl space to find the dip is where two subfloor panels are joined together using a 2x4 piece of wood between the joists. The 2x4 is not attached to the joists. My though is to jack up where the 2x4 is until the floor is level and then adding L brackets attaching the 2x4 to the joists. Will this work? Are there better options? TIA. -Pat
dreiding is offline   Reply With Quote
Old 01-23-2019, 04:13 PM   #2
Rewards Points: 32
Re: Subfloor with small dip
Here's a picture..
Framing basement - is my small powder room TOO small? suburbanbeat Remodeling 16 12-21-2018 06:56 PM
Small semi-raised patio NewbieDIYer Landscaping & Lawn Care 1 05-25-2017 05:33 PM
Removing small walls Eap80 Building & Construction 8 07-15-2016 09:24 AM
Small dip in concrete floor. kath81 Flooring 3 11-12-2010 05:32 PM
Curved Small Stage jalaux Carpentry 1 07-09-2006 10:57 PM
