Subfloor Help - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-24-2009, 11:56 AM   #16
Registered User
Rewards Points: 526
As Bjb mentioned, if ever a water leak.... I would use plywood, not OSB, over everything, here is why:http://www.rci-online.org/interface/...ton-murphy.pdf Plus I hate the way OSB out-gasses for months later. What you now have for the vapor barrier is about the best there is.
Be safe, Gary
Old 09-24-2009, 12:33 PM   #17
Rewards Points: 79
Be safe, Gary
perfect...thanks again for all of your help gentlemen
Tom5151 is offline   Reply With Quote
