Stuck In A Doublewide! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2014, 08:05 AM   #1
Location: I live in Mims, Fl. where you can feel the launch from the cape.
Stuck in a doublewide!
Hey, I joined this to find out about the roof, all done. Thank you very much. Now I have found non-toxic black mold in the ceiling of the kitchen. So bummed! Question is, do I tackle the ceiling, wall that is water damaged or the floor first. Be nice, I'm working my butt off to make this place home.
ande1 is offline   Reply With Quote
Old 07-22-2014, 08:07 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 742
I would do all 3 at the same time. Need doing anyway. Make one mess and not have to cleanup 3X is what I would do.
The Following 2 Users Say Thank You to yuri For This Useful Post:
ande1 (07-22-2014), r0ckstarr (07-22-2014)
Old 07-22-2014, 11:01 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,580
Sounds like a good time to rip everything out.
Old 07-22-2014, 07:42 PM   #4
Oh wouldn't I just love to tear it all out and start from scratch! Being on SSI makes it a little difficult, so I think I will start at the top and work my way down. Not 3 messes, just 1 continuous mess. I will be back.
Old 07-24-2014, 11:00 PM   #5
Rewards Points: 248
DIY or working alone often means just that - doing things multiple times, esp cleaning up. As for making mistakes, I almost killed a tree with all the construction garbage I left around it. That would have been very expensive mistake.
carpdad is offline   Reply With Quote
Old 08-05-2014, 11:14 AM   #6
Moving right along, lol. Have removed the subfloor in front of the back door. Full 8' by 4' sheet of plywood. All ready to put the new wood down and found that there is still a leak in the wall. Think I have that covered. Now, is it feasible to put a wood door where the trailer door is? Has anyone done it before and what kind of problems am I going to run into?
Old 08-05-2014, 07:38 PM   #7
Retired Moderator
Rewards Points: 7,174
You need to check a few measurements---your walls may not be as thick as a standard house wall---
The height might also be shorter than a standard prehung door---
York Furnace pressure switch stuck open troubleshooting divergent HVAC 47 03-10-2014 07:42 AM
Clothes getting stuck in dryer Centex2011 Appliances 4 10-30-2013 08:32 AM
stuck and I mean stuck brass tub stopper tapple2 Plumbing 14 02-27-2013 05:32 PM
Replacing window sill, but now it's stuck. rosemonster Carpentry 25 01-25-2011 05:31 AM
