Strongback Joist Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-15-2016, 12:09 PM   #1
Rewards Points: 2
Strongback joist question
While removing old flooring in the attic i removed one of the strongback joists without realizing what it was. The other is still intact. Unfortunately the wood cracked as I hammered it out and i'll have to get some new one .
How critical is it to replace the one I took out ASAP , or I am ok to wait until I finish the insulation project.
thanks
picture see below.
StanleyDIY is offline   Reply With Quote
Old 02-16-2016, 10:04 PM   #2
Rewards Points: 1,036
It depends on how long you plan to wait. Check the weather to be sure there is not a big storm coming. if the weather is good with no high winds and such you should be ok for a few days.
Mingledtrash is offline   Reply With Quote
Another tight rim joist insulation question jw138 Insulation 9 01-30-2016 08:48 AM
ceiling joist structural question rdc Building & Construction 4 12-30-2010 11:18 AM
I have a question about deck joist. max_wonder00 Building & Construction 10 10-04-2010 01:41 AM
Joist sistering question for 20' room adammb Building & Construction 11 01-22-2010 10:26 PM
question about joist hangers with drywall redss Drywall & Plaster 4 10-15-2009 03:01 PM
