Strengthen Rafter - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-19-2010, 08:18 AM   #1
Strengthen rafter
Per drawing. Would adding this 2x4 strengthen the rafter from flexing and eliminate the need for an interior bearing wall since the 2x6x14ft rafter is not adequate? Initially I was going to build a 2x4 frame to flatten the ceiling for the 6 ft (add more insulation) but I thought maybe I could bolt the 2x4 for additionall support. The original 2x6 x 14 24 oc has been in place for > 50 years (NE we get snow) but have sagged probably considerably until I replace them with 2x6 pt. I'm inclined to think this won't help much but wanted other opinions before I build an interior bearing wall and lose the openess of the room.
Thanks.
eastside is offline   Reply With Quote
Rafter Calculations - help me understand, please. wombosi Building & Construction 25 09-11-2011 10:48 AM
Rotted Lookout Beam Supporting Barge Rafter rwbil Building & Construction 1 08-15-2010 11:40 AM
Rafter Ties on Vaulted Ceiling timsgills Building & Construction 2 01-07-2010 03:02 PM
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 06:03 PM
rafter questions - structural rtoni Carpentry 11 09-13-2007 05:40 AM
