Storage Closet Under Metal Carport - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By de-nagorg
  • 2 Post By mark sr
  • 2 Post By chandler48
Old 05-28-2018, 12:03 AM   #1
Rewards Points: 49
Storage closet under metal carport
I am putting in a 2 bay metal carport, and want to build in a storage closet in the front of one bay, to measure about 6' x 10'.
Thinking I will frame with 2x's and finish out with hardie board and batten.
My concern is water intrusion up under the walls. My current carport, in heavy rain or rain with wind, will get the slab wet almost all the way across (18' x 24'). Slab has a slight crown to it, but surface tension/puddling will make for about 1/8" of water in places, on occasion.
I am thinking I should seal the PT plates to the concrete floor with construction adhesive, then maybe also caulk the outside wood/concrete junction (before sheathing/hardie).
And then the door. This is mostly for yard tools. Lawn mowers and stuff will be in my barn. I'm thinking to let the bottom plate run continuous, thru the doorway, letting the doorway threshold set up 1-1/2" more than normal.
Either this attempt to seal water out, or build it on a subfloor, PT joists (2x's) on edge on the concrete, 3/4 subfloor over that, and vented at the ends of each cavity to let water and moisture come and go as it will. One step up as you enter the door.
I am open to advice, comments, ideas. Thanks!
ranger12 is online now   Reply With Quote
Old 05-28-2018, 03:28 AM   #2
JUSTA MEMBER
Rewards Points: 982
Re: Storage closet under metal carport
I would put it up on blocks, They make 8X16 concrete blocks that are about 3 inches thick.
I would start with several of them laid flat on the concrete floor of the carport, then build the closet ( shed) as a usual shed, with the floor joists sitting on the blocks, shimmed for level, and a plywood floor, and walls and roof.
The blocks will possibly need sealing to keep them from wicking any water up to the wood floor, but that is easy with a concrete sealer.
ED
123pugsy likes this.
de-nagorg is offline   Reply With Quote
Old 05-28-2018, 06:29 AM   #3
retired painter
Rewards Points: 1,334
I'd also run a course of block first, then the wood. Easier to seal it from rain and less danger of the wood rotting.
123pugsy and de-nagorg like this.
mark sr is offline   Reply With Quote
Old 05-28-2018, 07:08 AM   #4
Naildriver
chandler48's Avatar
Rewards Points: 626
Blocks are a good idea, but you should seal them in some manner to prevent water wicking. I built one for a client, but it was a little different from what you describe. It worked well and had no water infiltration. Use sill seal and OSI Quad Max to seal the PT bottom plate down and OSI to seal the outer part of the plate. Allow your siding to extend slightly below the bottom plate, but not enough to become wet from splashing.
de-nagorg and Nealtw like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Ad hoc Storage Closet: Door Handle Height Augster Windows and Doors 1 10-08-2014 08:31 AM
Doors for Over Closet Storage gnikyerffej1 Carpentry 3 01-01-2014 09:24 PM
Metal Carport Cover Assembly bforrest13 Building & Construction 0 07-09-2011 10:15 AM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 02:23 PM
Storage Loft in Metal Shed Traveller Building & Construction 6 09-30-2007 04:08 PM
