Stone Chimney Needs Major Help. - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-13-2010, 10:06 AM   #16
Concrete & Masonry
Rewards Points: 518
The column strategy would work with 16" chimney block used as the backing/structure. The easiest approach would likely be:
A) Build out a wood framed "box" and use cultured stone or natural thin veneer stone.
B) Re-use your existing stone to build a 5-6" veneer to simulate a chimney.
C) Re-use your existing stone and lay them against a CMU (block) or wood backing, tied together with wall ties per code.
There's many, many details missing here, but A is by far the easiest approach, with C being the most time consuming IMO.
How about a picture of the whole thing from a little farther back?
jomama45 is offline   Reply With Quote
Old 10-13-2010, 10:10 AM   #17
Rewards Points: 582
This is the best method of taking down the stack.
stuart45 is offline   Reply With Quote
Old 10-13-2010, 11:16 AM   #18
Rewards Points: 150
jomama....here is the other pic. I also don't have much money that I want to spen so I would definitly want to reuse the stone I have in some way. I understand I will need to spend money but I would like to keep it to only necessary money..
Thanks again
Stone chimney needs major help.-chimney-007.jpg   Stone chimney needs major help.-chimney-008.jpg
organick is offline   Reply With Quote
Old 10-13-2010, 11:29 AM   #19
Rewards Points: 1,232
Well, that is a horse of a different color after seeing that picture. I would be comfortable repairing that in place, subject to how it is attached to the house.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 10-13-2010, 11:29 AM   #20
Concrete & Masonry
Rewards Points: 518
Looking at the additional pics, I'd suggest going with option B. Than you merely need to patch in the soffit & fascia to match. Leaving the chimney project proud of the roof is not a good option.
This way you will have plenty of stone to select from. Don't expect this to be a weekend DIY project either, but if using limited nights/weekends while working a typical 40 hr. day job, more like a month plus.
Old 10-13-2010, 12:29 PM   #21
Rewards Points: 150
Really??
Old 10-13-2010, 12:31 PM   #22
Rewards Points: 150
Where can I get info on how to? Is it so time consuming because you have to build it in layers?? Just curious
Old 10-13-2010, 12:39 PM   #23
Sure, 9' is a hell of a lot different than 15 or 20'. I would make sure it is attached to the house, open the top (actually, I would remove it to below fascia and repair that) to get a look inside, then begin grouting and tucking with an appropriate mortar. I would also place (in shallow 1-2' lifts) concrete in the interior.
Old 10-13-2010, 01:30 PM   #24
Concrete & Masonry
Rewards Points: 518
Be honest, no YOU wouldn't. You'd start over from scratch with something completely unique if it was YOURS...............
I doubt there's much of anything at all still tieing that to the house. The second picture makes me aprehensive to just fill it with concrete. You've also got to find a good way to finish the top off, as a simple mortar wash will only create more problems when the center is filled solid.
Old 10-13-2010, 02:27 PM   #25
Rewards Points: 582
If it was mine I would rebuild it. I would also probably take it a bit higher and put a pot on top, as I don't really like the look of an external stack partially removed. There is quite a serious crack in it.
If I went down the pointing road I would probably use a pointing gun to get the mortar well into the wall.
If using a lime mortar I would go for a 3.5 hydraulic lime and sharp sand mix.
Old 10-13-2010, 02:41 PM   #26
Rewards Points: 150
I took these 2 pics through the hole in one side. Can sort of see the back on the inside.
As I said this has no real significance. I just don't want it to fall or cause me bigger problems. If i can fix so it will stay in place thats great. If I absolutely have to rebuild it I will. I definitely wont build it up above the roof. I just want it solid and safe.
Stone chimney needs major help.-chimney-009.jpg   Stone chimney needs major help.-chimney-010.jpg
Old 10-13-2010, 04:21 PM   #27
Rewards Points: 582
The problem with random stonework is that it does not have the stability of brickwork of the same thickness. My cottage is built from random stone and has stood up for hundreds of years, but the walls are 2 ft thick. Thinner random stone walls are much less stable. Most of the chimneys round here on stone houses are built from brickwork as they are too thin for random stone.
I think the safest way would be to follow jomama's advice for the rebuild.
Old 10-13-2010, 09:46 PM   #28
Rewards Points: 474
If it were on my house I would think about taking that structure down and siding it over. What is the attraction of a stone structure on the side of your house that was obviously once a chimney but has since been capped off with concrete at the fascia and no longer looks anything like a chimney. No offense but if it were a limb, it would be an amputated one and that concrete on top just looks like a stump.
Store the stones in a pile and and think of something else creative you can do with them like a small decorative wall or a http://www.diychatroom.com/f49/stone...firepit-71777/
Jim F is offline   Reply With Quote
Old 10-13-2010, 11:30 PM   #29
Rewards Points: 150
Jim, its not that I think anything is that great about it. It is just there already. Tearing it out and siding it would require buying siding when I already have stone. Although I do hear you on some level about it.
Old 10-14-2010, 08:59 AM   #30
Concrete & Masonry
Rewards Points: 518
Stone work is just time consuming in general. Stone are very dense in nature, and don't "suck" the moisture out of the mortar very fast. Thus, you're limited on how much stone you can lay at one time before it becomes unstable. The fact that it's a small, tall area and the stone are round, and the time piles up quickly. Not saying you can't do it realistically, as it's a good DIY project if you have the time and patience. Good luck.
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 07:00 PM
Big scary stone chimney Grass Valley Gal Building & Construction 6 08-28-2008 06:31 AM
Adding stone to existing brick chimney TVC15 Building & Construction 5 08-13-2008 05:19 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
