Staircase Level - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-29-2009, 05:50 PM   #1
staircase level
my staircase slopes to the left. When set on the stair treads I have to lift the level up about 3/4 of an inch for it to be level. How can I raise this? What I see right now is the stringer is nailed into the studs on he way up he case. I was thinking about cutting those nails, jacking that stringer up to level and renailing into the studs. Is this the way to go?
Walls on the side and under the stairs are removed. There is total access.
sharp is offline   Reply With Quote
Old 12-29-2009, 07:19 PM   #2
Registered User
Rewards Points: 526
Sounds like a basement set? Measure all the risers and treads, from side to side. The very bottom riser or the very top riser may be off. OR, the carpenter traced each stringer and compounded the errors.
Be safe, Gary
Old 12-29-2009, 08:28 PM   #3
firehawkmph's Avatar
Rewards Points: 2,586
Any pics available?
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 12-30-2009, 07:02 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Is it out of level the same amount on the top step and the bottom? Is the floor out of level the same amount where the stair ends top and/or bottom?
Old 12-30-2009, 01:08 PM   #5
Registered User
Rewards Points: 526
Hmmmmmm.... this sounds a lot like this: http://www.diychatroom.com/f19/replace-treads-60496/
Be safe, Gary
Old 12-30-2009, 01:25 PM   #6
Be safe, Gary
Indeed
Leveling Kitchen Cabinets for Granite - how level?? vsheetz Kitchen & Bath Remodeling 13 03-02-2012 07:54 PM
level or not level toilet? ron0805 Plumbing 4 10-26-2009 04:16 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
Converting an open staircase to a "closed" staircase? tony1853 Building & Construction 7 01-05-2009 01:55 PM
