Stain On My Brick - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-23-2009, 09:41 AM   #1
Rewards Points: 150
Stain on my brick
Hi guys,
Tried this post in the roofing section, and didnt get any feedback. You guys have any ideas?
I basically have these black marks / streaks on my brincks, and I think its from the rain water rubbing off the flashing or something...do you think if I installed new flashing I could avoid this going forward?
Here are some pictures...
Any info / feedback would be appreciated!
Thank you.
James
sbmfj is offline   Reply With Quote
Old 10-24-2009, 01:00 AM   #2
Garage Door Installation
It is best you try first a simple cleaning solution on one part and see how it goes. I found this article at ehow.com
http://www.ehow.com/how_113267_remove-stains-brick.html
You need a ladder though to reach those stained part. If it wont work, check the real probable cause by checking your roof. Maybe it's not water, or something is leaking from there.
FLGarageDoors is offline   Reply With Quote
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 03:04 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
