Spray Foam:closed Cell - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-05-2008, 01:42 PM   #16
Girla,I wont have to vent because I have no attic space just cathedral.I will control humidity with my hvac.I would have to vent if I were just stuffing fiberglass batts in between the rafters.But because Im using a closed cell spray foam theres no moisture that needs to be vented,I hope haha.I will also install a whole house fan to pull air out if needed.But in your case I think there are vents that attatch to the hips and the peak but you would have to have outside air entering so it can exhaust out the ridge vents.
A.Pierce is offline   Reply With Quote
Old 10-26-2009, 09:20 AM   #17
I am also considering spray foam for the crawlspace (~5' tall) in a house in Lake Tahoe, Calif but am surprised at the prices. Does anyone know who has the best prices? As a builder, I plan to do the work and just need the material and spray equipment. Thanks!
Steve Burke is offline   Reply With Quote
spray or brush baseboards? mathdan Painting 20 06-05-2015 09:41 PM
spray paint dry time question joeyboy Painting 12 01-15-2010 05:21 AM
closed cell insulation in attic Dennis Doucette Building & Construction 7 03-16-2007 09:08 PM
Spray Texture Piney Painting 4 03-02-2007 12:24 PM
What Bug Spray for inside and outside home? simple50 General DIY Discussions 2 06-02-2005 08:26 PM
