Solid Aluminum Soffit Panel For Porch Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-13-2016, 05:20 PM   #1
Rewards Points: 110
Solid Aluminum Soffit panel for porch ceiling
I asked this in another post along with other questions but this one didn't get answered.
Is it ok to use all solid (non vented) aluminum soffit panels for your porch ceiling.
For appearance, I would like to do ALL solid on ceiling, up to where the beam is that the columns are under. Then in front of that beam where there is more soffit area near roof edge and gutters, I would go back to using alternating vented and non vented that is required for proper ventilation.
Sandywjo is offline   Reply With Quote
Old 02-13-2016, 05:30 PM   #2
Rewards Points: 7,806
With the soffit area vented you should be all set using solid panels in there.
Bud
Bud9051 is offline   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
Sandywjo (02-13-2016)
Old 02-13-2016, 05:54 PM   #3
Rewards Points: 110
That is so helpful to know sir, I have been wondering about this for weeks while trying to pick out materials! Thank you!
Old 02-13-2016, 06:27 PM   #4
I got to thinking about your porch and want to be sure of a couple of details.
1. Is there a high vent to allow hot air to escape?
2. Is the vented space above the soffits open to the space above the ceiling in that porch area?
There are options if there is no high vent.
Bud
joecaption (02-13-2016)
Old 02-13-2016, 07:45 PM   #5
Rewards Points: 18,244
Not enough info and no pictures.
Enclosed porch?
Old 02-13-2016, 08:03 PM   #6
Rewards Points: 110
Currently the the only "vents" on the porch ceiling is the from the vented aluminum soffit we have up now. I am not sure if the space above the soffits is open to the space above the porch ceiling or not. All I can see is the soffit running across. I was not living here when the last was installed. I suppose we could investigate that. Not knowing anything about this exact situation (which is why I asked) I never thought about heat getting trapped on the porch with it being completely open space to the outside. The porch is only about 5 foot deep by 22 feet long. I hoped as long as the soffit in front of the beam (near edge of roof had the venting we would be ok. I have alot to learn! Here is the pic of what we currently have.
Solid Aluminum Soffit panel for porch ceiling-fullscreen-capture-2132016-75520-pm.jpg
Old 02-13-2016, 08:08 PM   #7
Rewards Points: 110
Enclosed porch?
We live in Ohio, and I just tried to post a pic but its dark out, I may need to take more tomorrow when its light out. My porch is about 5 foot deep and 22 feet long. Completely open porch. Not sure what other details would be helpful. This porch is in constant shade at all times so no direct sun on it.
Old 02-13-2016, 08:38 PM   #8
I assume that is soffit to the right and porch to the left of that beam?
With a sloped roof above there almost has to be a continuous cavity from fascia in and over the ceiling.
In cases where there is no high vent you have to rely on some wind, it doesn't take much. And you double the vent area, all low.
Bud
Old 02-13-2016, 08:56 PM   #9
Rewards Points: 110
Yes, the porch is the left side of the beam, soffit to roof edge on the right.
Tags
aluminum soffit , porch ceiling , solid soffit panel
New meter panel for 1955 house. Use old breaker panel as sub panel. mitchedo Electrical 5 10-11-2015 11:24 AM
panel upgrade options for new HVAC installation buyabook Electrical 12 09-14-2015 11:39 PM
Aluminum double panel vs new vinyl double panel. bcdinh Windows and Doors 1 05-16-2014 12:32 PM
how to frame angled soffit from ceiling soffit to wall BlueBSH Building & Construction 4 06-19-2012 08:56 AM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 01:10 PM
