Soffit Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-20-2009, 08:47 PM   #1
Rewards Points: 1,100
Soffit Question
I have soffits that follow a pattern. Two solid rectangles, then one solid perforated rectangle.
I think the soffits sections come in the pattern of solid, perf, solid.
Are these installed hook and loop like siding is?
How hard is it to slide one section over to access the underside of the roof?
Is a special too needed?
handy man88 is offline   Reply With Quote
Old 07-20-2009, 08:58 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 586
I checked mine as I want to open them up to put holes in the plywood for attic venting, and without looking too deeply, it seems that it's just a couple screws, in my case squares, probably red screw driver. Not sure if they are glued too though, hopefully not!
Old 07-20-2009, 11:00 PM   #3
Rewards Points: 150
Three weeks ago i "hung" about 45 foot (two solid one perforated pattern) and the stuff i used (homedpot or lowes) was simulare to the locking of siding.
Some where along the lines i seen older aluminum soffits and it was the same also.
Don't know if this is the standard or not.
Pretty sure you will have to take the gutter off and the fassia "wrap" off before you can get to the soffits. Maybe you can bend the wrap carefully depending on how much of an lip is bent over.
Info in this thread might be helpful.
http://www.diychatroom.com/f2/soffit...project-49120/
_
iMisspell is offline   Reply With Quote
Soffit venting question dat5574 Roofing/Siding 2 03-03-2009 10:21 AM
Soffit span question Yasla Building & Construction 3 01-04-2009 03:37 PM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 04-30-2007 11:14 PM
Question re: fiber-cement soffit material MichaelinOmaha Carpentry 4 10-12-2006 07:30 PM
Soffit installation question milano Roofing/Siding 4 02-04-2006 10:13 PM
