Soffit Framing In Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By kwikfishron
Old 07-30-2016, 07:24 AM   #1
Rewards Points: 60
Soffit framing in basement
I have to install a soffit around ductwork in my basement. The soffit will be about 4 feet wide and run right down the center of my basement (about 28 feet long). The soffit will not attach to any walls, except at the two ends.
I've seen two ways to do this. One way, I'm guessing the traditional way, would be to basically frame out the sides with 2x4s just like a mini wall and then turn other 2x4s on their side to connect the two sides.
I've also seen websites suggest using 2x2s and 1/2" plywood to frame the sides before using 2x4s that run between the two.
Is one of these methods better than the other? I already went out and bought the plywood and 2x2s, but now I'm a little concerned that there may not be enough lateral support.
Logan176 is offline   Reply With Quote
Old 07-30-2016, 09:37 AM   #2
kwikfishron's Avatar
Rewards Points: 178
Re: Soffit framing in basement
Either way is fine. The 2x2 plywood method can be a plus in tight spaces but now you're buying plywood.
Mingledtrash likes this.
kwikfishron is offline   Reply With Quote
Old 07-30-2016, 07:11 PM   #3
Rewards Points: 1,036
The ply wood is stronger but i would suggest using 2x4 with the ply wood instead of 2x2.
Mingledtrash is offline   Reply With Quote
Old 07-30-2016, 07:21 PM   #4
Framing Contractor
Rewards Points: 88
With it only being 4' wide, you could run the 2x4's on the flat and pick up 2" of height. Any longer than that and it gets a bit sketchy.
sixeightten is offline   Reply With Quote
Old 07-31-2016, 10:22 AM   #5
Not so new
12penny's Avatar
Rewards Points: 522
Or for something a little lighter in weight, I typically use 2 1/2" metal studs, wall track and 7/8" hat track. 10' ladder sections are assembled pretty quickly on a work table and they're easy to install by oneself.
12penny is online now   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
woodworkbykirk (07-31-2016)
Old 07-31-2016, 08:34 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
the steel stud method is much better.. its lighter weight and wont warp like wood does when it dries out
woodworkbykirk is offline   Reply With Quote
Old 07-31-2016, 09:12 PM   #7
jlhaslip's Avatar
Rewards Points: 708
Might also consider using MDF for the drops on the soffit.
It paints up really well.
2 by 2`s, properly nailed, would be not problem if they are purchased and nailed up right away. Select straight ones at the Lumber yard, not the gnarly ones. They warp badly if you leave them loose in the house for a period of time.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 08-01-2016, 10:57 PM   #8
firehawkmph's Avatar
Rewards Points: 2,546
I build a 2 X 4 wall on each side of the duct span, then I use 1 X 6 tongue and groove knotty pine to span it and also for the sides. Works very well plus it look nice when stained or painted. Adds a little texture to the room.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 08-02-2016, 09:56 PM   #9
mdf will work however its heavy.. you have to use construction adhesive with the nailers as well to ensure extra hold.. 2x2s wont just move if left laying around.. they will move even when installed as they dry out
soffit framing boilermaker27 Carpentry 3 11-03-2013 10:33 AM
Framing and finishing my basement: a best guess question HT4Me Carpentry 7 05-05-2013 10:26 PM
Finishing Basement - Framing with 2x2's mark2741 Building & Construction 13 12-25-2011 08:20 PM
Basement Framing ddave23 Building & Construction 4 10-30-2011 11:38 AM
Another basement framing thread fbaggins Remodeling 3 07-08-2010 12:48 AM
