Sleeper Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By cibula11
Old 05-25-2018, 01:18 PM   #1
Rewards Points: 818
Sleeper Floor
I'm wondering if there's a preference or "right" way to install a sleeper system over a wood subfloor to raise a sloped area in a room? The floor slopes, but does not bow and we're wanting to level it. We can't raise the foundation as that's really not a viable option for multiple reasons, but will be laying wood flooring and want to correct the floor as much as possible.
That being said, my initial plan is to install a sleeper (2x4 cut in a large wedge) on top of the subfloor/joists then screw new plywood sheeting over. Should the sleepers be installed on top of the joists or installed perpendicular to the joists? Or does it not really matter?
cibula11 is offline   Reply With Quote
Old 05-25-2018, 01:29 PM   #2
retired framer
Rewards Points: 4,686
Re: Sleeper Floor
If it is close to impossible to level from below, then I would put sleepers on top of the joists with glue and screws thru to the joists.
How will that effect thresholds to other rooms and door way heights
cibula11 likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
cibula11 (05-25-2018)
Old 05-25-2018, 01:32 PM   #3
Rewards Points: 818
Re: Sleeper Floor
Thanks! This is what I was thinking too. Thresholds, ceiling heights, all of it will have to remedied and yes, I've thought through that. This won't be a small scale project. All new interior doors, trim, etc. for the area being leveled. The home is 105 yrs old, so we can get away with certain aesthetic issues we encounter.
Old 05-25-2018, 01:38 PM   #4
retired framer
Re: Sleeper Floor
I helped a friend lift his house back in place, one corner was down 3+ inches. The basement floor was also out so he put sleepers and wood floor to level it. What he forgot is the outlets on the wall should have be adjusted to the new floor height.
Old 05-25-2018, 01:41 PM   #5
Rewards Points: 818
Re: Sleeper Floor
Yeah I don't think that will be too big of an issue for me. Only 2 outlets and both are high enough. One doorway has to be raised and new header installed but it's not load bearing so I'm not stressing about that. However, there's always a couple of things that show up when doing any remodel no matter how well you plan.
Nealtw likes this.
What is the minimum floor space required for a winder staircase vestaviascott Building & Construction 27 05-01-2015 11:36 PM
Floor joist replacement and reconfiguration WillK Carpentry 2 09-01-2011 09:01 AM
Sleeper floor with no access northwestsoul Flooring 0 08-12-2011 01:57 PM
cant deciding what to do about sleeper floor on slab acerunner Remodeling 1 05-14-2011 06:19 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
