Simple Roof Over A Shavings Bin - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-08-2015, 06:20 PM   #16
Rewards Points: 3,522
A rail on each side for rollers like a garage door or a slide system. Unistrut comes to mind for rails that will be stiff enough when supported on the far back end with a post when it is opened. Build the top of corrugated fiberglass barn roof panels or corrugated steel framed with 1x4s.
Old 02-09-2015, 08:25 AM   #17
Rewards Points: 526
I'd take ideas from the awning makers. Since you can weld, I'd use conduits for frame, heavy duty plastic tarp (uv resistant) stretched tight and a tackle to lift the whole thing and set aside for filling. You can frame out a rail as well for sliding the roof out of the way. If you have a snow load, you'll have to plan for sweeping the snow off/breaking ice from inside. I think metal roof is way too heavy duty for this application.
carpdad is offline   Reply With Quote
New home roofing rippling/deflection issue daldelta Roofing/Siding 22 05-24-2013 06:24 PM
Insulating kneewalls vs roof in 1929 house BadHouse Insulation 6 01-27-2013 03:58 PM
Simple lean to shed roof HANKNJAKE Building & Construction 5 05-02-2012 08:01 PM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 08:25 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
