Sill Plate, Sole Plate, Bottom Plate -- Please "un"-confuse Me. - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-04-2013, 09:55 PM   #16
cortell's Avatar
Rewards Points: 504
Confused. So you already have a wall there. You're replacing it with basically the same thing?
cortell is offline   Reply With Quote
Old 11-04-2013, 10:48 PM   #17
Dave88LX's Avatar
Rewards Points: 796
A "wall", you could say that. Look at that hunk though, I don't know if you'd want to keep that in place, I sure as heck don't!
I had a very low-quality DIY'er in this house before me and I want to make it right.
Dave88LX is offline   Reply With Quote
Old 11-04-2013, 10:49 PM   #18
Registered User
Rewards Points: 526
And you may need a "furnace room" to meet today's codes.
Slip some foam board under the plate (non-pt, check locally) with a continuous bead of caulking against the concrete floor for an air/thermal/capillary break to the cold slab/earth below to protect the studs/cavity insulation; http://www.greenbuildingadvisor.com/...-building-code
Egress; https://docs.google.com/viewer?a=v&q...33otStRi7Aff7g
Gary
Old 11-05-2013, 08:23 AM   #19
cortell's Avatar
Rewards Points: 504
OK. Well, the beam's surface looks to be in good enough shape where perhaps I would indeed just sand it and paint it the same color as the walls, on the beam underside and the side where it overhangs the 2x4 wall by 1/2" (3.5 studs + 1/2 drywall, against 3x1.5 beam). Now, the pictures do not show the column/beam connection. If that's unsightly, I would box the beam's underside and overhanging side and then build the wall up to the box.
Old 11-05-2013, 08:35 AM   #20
cortell's Avatar
Rewards Points: 504
Good call on the sealer under the plate. Embarrassed I forgot to mention that. Question, though. Isn't poly sill sealer good enough? Much easier to install--no cutting foam board into 3.5" or 5.5" wide strips, and it seems to be commonly used.
http://building.dow.com/na/en/applic...nsillplate.htm
Old 11-05-2013, 10:00 AM   #21
Dave88LX's Avatar
Rewards Points: 796
So the preferred method would be to use closed cell foam to provide the concrete plate barrier, and use standard lumber? The wicking up into the bottom of the studs is a great point I hadn't thought of.
Regarding the header, I would prefer to bring the drywall all the way up to the ceiling though.
I know my windows are ~34" x 34", I need to check how high they are off the ground. It's also a walk-out basement if that matters. My windows need to be replaced though down there (Well, in the whole house really but that's for a different year).
Old 11-05-2013, 12:46 PM   #22
Registered User
Rewards Points: 526
Add shims/strapping to the beam (only top perimeter) only and use 2x6 studs/plates.
The slab is poured on earth, with a 2' exterior perimeter (if to code- here) wide layer of foam board. Older houses = no foam board or vapor barrier under concrete slab. So you have a drywall wood framed wall absorbing heat from the HVAC ---8' x 35'? standing on a colder slab; enter conduction. Your climate location is not very severe and the ground temps will be warmer - with 6' down = warmer yet; http://www.epa.gov/athens/learn2mode...enrys_map.html
Heat loss is worse close to the perimeter, lessening farther in room; http://www.google.com/url?sa=t&rct=j...hj_I6fU2ymaUSA
The R-value if the sill sealer is about R-1, compared to 1" of XPS (r-5) or PIC (R-6.5 and a vapor barrier (capillary break, to boot); add the wood plate (R-1.25 per inch = R-2-) so total of R-3 compared to R-7 with XPS. A lot less of the wall being a "heat sink", IMHO.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
cortell (11-05-2013)
Old 12-03-2013, 08:59 PM   #23
Dave88LX's Avatar
Rewards Points: 796
Originally Posted by joecaption View Post
The nails need to be ACQ when nailing into pressure treated wood.
If not they will shortly rust out.
I looked up the costs.
$50/2000 for the regular .131" x 3.5"
$80/2000 for galvanized .131" x 3.5"
Is there a cheap way around this versus buying both? Any way to get smaller quantities?
Can I:
A. Put down a PT plate attached to concrete, then bottom plate of wall attached to pt plate with galv (hand) nails, and air-nail the rest of the wall?
B. Use standard wood as the bottom plate on the concrete with the foam between the the bottom plate/concrete?
Old 12-03-2013, 09:38 PM   #24
cortell's Avatar
Rewards Points: 504
Can I:
(a) Absolutely! I'm not sure why you think using a nail gun is important. You can frame an entire house with a hammer (though it might take you three times as long), and in fact, that's how it was done for hundreds of years.
(b) Absolutely! In fact, there was a thread recently where this was discussed. At least one well respected contributor to this chatroom believes foam and regular wood is preferable to using a PT sole plate, and his reasoning makes lots of sense to me.
Old 12-03-2013, 09:55 PM   #25
Dave88LX's Avatar
Rewards Points: 796
Awesome. I don't want to buy an $80 box of nails. I don't think it's important, it's just that I have one and I want to use it. :D
I pulled out the old door jambs today for the door between the upstairs and the basement. Drywall-2x4-misc wood jammed in there-drywall-wood paneling is how my wall is built. I'm just going to paint the paneling, extend the jamb, and call it good on this particular wall...
I'm not opening that can of worms. There is a drop ceiling attached to the wall and it will just be one problem leading to another into another.
Old 12-04-2013, 08:30 AM   #26
kwikfishron's Avatar
Rewards Points: 72
Most places that rent nail guns also sell nails by the rack.
kwikfishron is offline   Reply With Quote
Joists, Sill Plate, Foundation and broken main beam Bonebag Building & Construction 14 02-03-2013 08:40 PM
Sill plate hold down bolts jrepp44 Building & Construction 8 11-08-2012 10:20 PM
Rotted sill plate and broken joist repair netlinks Building & Construction 6 07-17-2012 11:27 PM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 09:08 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
