Sill Plate Damage / Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By HenryMac
  • 1 Post By ClarenceBauer
  • 1 Post By LazarusGXP
Old 10-20-2018, 05:45 PM   #1
Rewards Points: 4
I am currently replacing some trim with PVC and found some damage to the sill beam. I believe this is old powder post bettle damage common in older homes. There was clearly remediation efforts in the past and i see no evidence of anything active in the area. My question is, what would you do before covering up the sill plate again with trim?
I've cleaned out the rot down the sound wood. Should I use minwax wood hardener for good measure? Clear coat? Spray it for future insect repellent? Place poly where i can as a capillary break?
I can possibly wedge some plywood in the larger voids as a shim. Or should i just spray foam wherever I can and call it good? Thanks for your comments!
Sill Plate Damage / Repair-20181020_160349_1540071774208.jpg   Sill Plate Damage / Repair-20181020_163601_1540071794885.jpg   Sill Plate Damage / Repair-20181020_163609_1540071814746.jpg   Sill Plate Damage / Repair-20181020_163618_1540071848070.jpg
LazarusGXP is offline   Reply With Quote
Old 10-20-2018, 05:52 PM   #2
HenryMac's Avatar
Rewards Points: 1,002
Re: Sill Plate Damage / Repair
I'd soak it down really good with Woodlife CopperCoat Wood Preservative, https://www.acehardware.com/departme...ealant/1363498
Then use Great Stuff Pest Block spray foam to fill up any gaps, https://www.amazon.com/GREAT-STUFF-P...SIN=B007TUF0FY
then cover it back up.
Good luck with your project... and welcome to the forum.
Sill Plate Damage / Repair-great-stuff-pest-block.jpg
Nealtw likes this.
HenryMac is offline   Reply With Quote
Old 10-20-2018, 06:00 PM   #3
Rewards Points: 92
Check out Abatron Liquid Wood & Abatron Wood Restoration also Abatron Wood Epoxy.
stadry likes this.
ClarenceBauer is online now   Reply With Quote
Old 10-20-2018, 06:41 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 29,434
What henrymac said but I think I might also paint it before covering.
Old 10-20-2018, 10:30 PM   #5
Rewards Points: 4
Good stuff, thanks! HD/Lowes/Ace don't seem to stock CopperCoat. I was hoping to take care of this tomorrow but I will hold off until I get some. Thanks again, I didn't know this stuff existed.
Old 10-20-2018, 10:59 PM   #6
retired framer
This will do it
https://www.homedepot.com/p/Copper-G...per1/100203025
Old 10-20-2018, 11:50 PM   #7
Rewards Points: 4
This will do it
https://www.homedepot.com/p/Copper-G...per1/100203025[/QUOTE]
Thanks. For some reason no homedepot stocks it near me in Connecticut (within 100 miles according to the website). I'll double check tomorrow though.
Nealtw likes this.
Old 10-21-2018, 12:02 AM   #8
retired framer
Thanks. For some reason no homedepot stocks it near me in Connecticut (within 100 miles according to the website). I'll double check tomorrow though.[/QUOTE]
Any lumberyard that sells treated lumber and some paint stores may carry a similar product.
Old 10-21-2018, 04:32 PM   #9
Rewards Points: 2,560
abatron's been good to us over the years as has the 'west' system
Old 10-21-2018, 09:16 PM   #10
Rewards Points: 1,824
Dittos on the preservatives. I wouldn't use epoxy filler, that's for exposed wood that you can't replace for some reason and it has no structural value. I would use insectproof spray foam after the preservative in those openings just to keep bugs and vermin from getting in.
Interesting that you seem to have two vintages of concrete in that foundation, with a kind of a seam there. Looks like maybe someone grew the house a foot or two.
ChuckF. is offline   Reply With Quote
Old 10-21-2018, 09:56 PM   #11
Rewards Points: 92
If you follow the manufactures written instructions on the use of Abatron to restore rotten wood this product will work & yes it will restore the wood member back to its original Structural strength. I have used this product dating back to 1984 on a Church constructed in 1700 in Goose Creek SC.
It is St James Church on snake road. if you check the Preservation Briefs the picture in the upper right corner on the front page is the Church.
This product is specified by Architects & Engineers for restoration on Historic Buildings . Also it is used by The National Park Service for Historic restoration of wood.
gap beneath sill plate mid-rise9 Insulation 1 08-16-2016 04:20 PM
Sill Plate Repair with Vinyl Siding jevchance Carpentry 7 09-12-2014 11:04 AM
Sill plate, sole plate, bottom plate -- please "un"-confuse me. Dave88LX Building & Construction 25 12-04-2013 08:30 AM
How short can sill plate pieces be ? tuckerz Building & Construction 2 10-04-2009 04:41 PM
sill plate repair over block foundation MARLE Building & Construction 14 05-04-2009 09:03 PM
