Sill Plate Anchors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-22-2017, 01:35 PM   #1
Rewards Points: 160
Sill plate anchors
I will be replacing approx a 7' length of rotten sill plate that is attached to the concrete slab at the front wall of the house with PT lumber, and using a foam barrier under the sill plate as well. For such a small expanse is it OK to use split drive concrete anchors to attach the new sill plate? I plan on spacing the anchors every 12" or so. A second option is to use Tapcon anchors.
Using split drive anchors seems to me the simplest and quickest way to attach the 2x4. The problem that caused the damp sill plate has been resolved. It was due to earth and dead leaves piling up over many years in the flower bed outside the exterior wall, thereby cutting off all the weep holes in the exterior brick veneer.
ggano is offline   Reply With Quote
Old 10-22-2017, 01:52 PM   #2
Rewards Points: 1,305
Re: Sill plate anchors
Anchors every 12" is a little overkill. For a 7' length you really only need 2 drop anchors, (provided they are no more than 6' apart) and 1/2" diameter... but 3 wouldn't hurt... and maybe one near each cut end of the existing plates.
See R403.1.6.
XSleeper is offline   Reply With Quote
Old 10-22-2017, 02:40 PM   #3
Rewards Points: 160
Would 1/4" split drive anchors be ok to use? I was going to use more due to the smaller diameter of the anchor.
Old 10-22-2017, 04:57 PM   #4
Oso954's Avatar
Rewards Points: 926
When the code (r403.1.6) says anchor bolts are 1/2 inch minimum, you can NOT substitute smaller ones, no matter how many you use.
A drive anchor cannot (in my area) be substituted for a wedge anchor or epoxy embedded Bolt.
You are not anchoring the bottom of the wall, you are tying the entire house down so it doesn't come off the foundation in extreme conditions, such as high winds or earthquakes.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
ggano (10-22-2017)
Old 10-22-2017, 08:49 PM   #5
Rewards Points: 160
Thanks, I will go with the 1/2" wedge bolt anchors. What is the recommended spacing?
Old 10-22-2017, 09:20 PM   #6
jlhaslip's Avatar
Rewards Points: 708
Min 4 ft where I am.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Foundation sill plate rot Barry1685 Roofing/Siding 14 07-17-2017 11:23 PM
Replacing sill plate in the gable end dbcriss General DIY Discussions 7 12-28-2016 05:24 PM
Joists, Sill Plate, Foundation and broken main beam Bonebag Building & Construction 14 02-03-2013 08:40 PM
How short can sill plate pieces be ? tuckerz Building & Construction 2 10-04-2009 04:41 PM
