Siding - Water Shielding Corners - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-05-2010, 09:08 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 2,004
Siding - water shielding corners
Is it necessary to use a membrane (like Vycor) under the cornerboards and inside corners or will house wrap be adequate?
If so, what is the order of the layers... house wrap, membrane, cornerboard?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 05-05-2010, 09:11 AM   #2
i think if you want to be really slick rip strips of roof ice shield for out side corners. inside corners i think will bunch up
The older I get the better I was
Old 05-05-2010, 09:20 AM   #3
kwikfishron's Avatar
Rewards Points: 838
30 lb. ASTM felt everywhere is all you need.
Don’t cut off at corners, wrap around.
kwikfishron is online now   Reply With Quote
Old 05-05-2010, 10:02 AM   #4
I have gas!
Thanks, I've already got Tyvek up, so I guess I can skip the membrane. I wasn't sure if I needed additional waterproofedness at the corners.
Old 05-09-2010, 02:13 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
i always install metal flashing to all inside and outside corners,depending on the corner width and weather exposure this could be anywhere from a 4x4 up to a 12x12
Siding - water shielding corners-img_0698.jpg   Siding - water shielding corners-img_0700.jpg
Tom Struble is offline   Reply With Quote
Old 05-09-2010, 02:17 PM   #6
Rewards Points: 838
Tom, your Tyvek is upside down.
Old 05-09-2010, 02:22 PM   #7
me a lefty Ron
Siding Inside Corners scott j Building & Construction 11 03-03-2010 06:30 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
