Siding Tips/Tricks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-29-2010, 11:43 AM   #1
Rewards Points: 156
Siding Tips/Tricks
I asked for tips when installing garage doors and got great results, so I'm gonna try it again for siding...
Doing my first siding job this weekend. It's not a big job, around 2.5 square. Involves removing old siding and putting up new double 4.5" dutchlap siding. Does anyone have any tips or tricks they want to share from their experiences?
Also, I've seen this be debated in a few places, but no clear cut answers
Tyvek under or over foamboard?
Maybe I'll add a picture when I get home from work.
Branden is offline   Reply With Quote
Old 07-31-2010, 03:58 PM   #2
Registered User
Rewards Points: 526
Tyvek over all sheathings, foam included.
http://www.vinylsiding.org/publicati...2007Manual.pdf
Well, I will alter my thoughts, it doesn't matter as long as one or the other is the drainage plane, not the siding: "Drainage plane on rigid insulation – An alternative to flashing, shiplapping, or sealing the XPS insulation for continuity of the drainage plane is to apply a housewrap to the outside of the insulation. The housewrap then becomes the continuous drainage plane. It is also possible to install the housewrap under the XPS insulation (this is a more common commercial wall system approach)." From:
http://www.buildingscience.com/docum...hermal%20break
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Branden (08-03-2010)
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
New siding, paint exsisting siding, or powerwash?? fixiechick General DIY Discussions 5 01-22-2009 11:50 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
