Siding- J Channel - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-29-2010, 06:58 PM   #1
Rewards Points: 356
siding- J channel
Do you see anything wrong with using 3/4" J channel for soffit versus 1/2"?
ugabulldog is offline   Reply With Quote
Old 09-29-2010, 07:07 PM   #2
kwikfishron's Avatar
Rewards Points: 828
Just an esthetics thing, plus the bugs and spiders will love that ¼” freeway you gave them.
kwikfishron is online now   Reply With Quote
Old 09-29-2010, 09:57 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
you can pack the back of of the soffit with a 1/4'' foam or backer board
Tom Struble is offline   Reply With Quote
Old 09-29-2010, 10:00 PM   #4
firehawkmph's Avatar
Rewards Points: 2,586
If your soffit material is 1/2", then why not just get the right J channel?
Mike Hawkins
firehawkmph is offline   Reply With Quote
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Vinyly siding J channel.. windowguy Roofing/Siding 6 07-02-2009 07:41 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
