Shower Wall Enclosures - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-08-2010, 07:31 PM   #1
shower wall enclosures
im looking to install the durawall shower walls in a 32" corner square shower. i read that you install them directly to studs. is it possible to install over greenboards. i have the option to move one wall out if i need to for the required measurments but i am worried about the shower drain not lining up. any help would be apreciated
handekaps is offline   Reply With Quote
Old 01-08-2010, 08:19 PM   #2
Remodeling Contractor
The drywall or shower wall system goes over the lip of the shower base. It is one or the other. And green board should not be used. It is outlawed in most places. But Home Centers still carry it since they cater to the innocent and uninformed general public. Green board was an experiment gone wrong. Research and history has shown that all installations in wet areas with this material will be moldy.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 12:05 PM
Shower pan/tile against concrete wall mgray87 Tiling, ceramics, marble 10 09-11-2009 11:50 AM
"Truing up" a shower wall jamie howe Tiling, ceramics, marble 2 08-03-2009 11:18 PM
