Shower Grab Bar Installed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 07:01 AM   #1
shower grab bar installed
hey guys.
i did a custom shower stall recently, and now, after everything is done, the cusomter wants a grab bar installed.
this is really annoying for several reasons. one is that the shower is already very narrow and the bar will make it about 4-5" even less.
i could put it on the showerhead wall, but it was the old porch wall and a lot of the sheathing was removed for plumbing, so it's basically drywall fastened to some sheathing, with big holes through to the studs. they don't want it there anyway.
there are two studs somewhere in the wall where they want it, 16" centers, but i'm not sure which end i started layout from.
the few grab bars i've looked at, are either longer or shorter than 16" anyway.
would it be enough to mount with toggle bolts through the grout and holding onto the durock? seems a bit sketchy to me.
otherwise, the siding is not up yet on the wall. i could theoretically peel back some housewrap, cut out a chunk of sheathing, rip out some icynene, and install some 2X12 blocking or something and it will be easy to hit with screws.
how would you guys do this?
thanks.
wombosi is offline   Reply With Quote
Old 07-26-2010, 07:24 AM   #2
www.No-Curb.com
JohnFRWhipple's Avatar
Sounds like you all ready know what to do.
You all ready have the answer.
Look into the force needed to be applied in testing these grab bars and you will be dropping that house wrap - I'm sure.
JohnFRWhipple is offline   Reply With Quote
Old 07-26-2010, 07:50 AM   #3
concretemasonry's Avatar
Rewards Points: 2,716
I just installed 3 shower grab bars on a fiberglass shower enclosure. They were stainless fixtures (looked good and the machine weld to the bolt flange was very good). Came from a big box store and were made in China if you can imagine that.
I installed 18" lengths with toggle bolts (3/16"). I also used silicone to seal all possible leakage points.
I don't know it they are the rated strength, but with 6 stout toggles on each bar, you would have to remove the enclosure to get them to let go.
You can always get longer screws if you are going through more layers, but probe before installing to make sure the length is OK. I had to cut 6 bolts for one because of the length of the open spaced in the cavity.
Dick
concretemasonry is offline   Reply With Quote
Old 07-26-2010, 02:09 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 388
Dick
If you want to find the studs in the wall, take a small drill bit and drill along the grout line one tile up from the base until you find the studs. If they are 16" OC then after you find one the second is easy. Mix up a little grout and patch your drill holes.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Failed shower pan in old tiled shower tmpyankee Plumbing 3 07-14-2010 06:43 AM
Help us make a remodel decision for selling home pleas 3detailer Kitchen & Bath Remodeling 11 04-27-2010 11:36 AM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 02:30 PM
Shower Arm Question brakea Plumbing 2 01-02-2009 05:58 PM
Backerboard under Fiberglass Shower Pan? BillyDIY Plumbing 2 12-17-2008 01:47 PM
