Should I Insulate The Ceiling Of My Unfinished Basement? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 10:24 PM   #16
Rewards Points: 5,348
Originally Posted by pjm View Post
Thanks for all the posts helped clear up a bunch of questions I had. As far as the radiant heat would that just heat the floor or would it also heat the air above where I put it? I had to take out a 6ft section of baseboard hw heat when I redid the kitchen and we're really feeling it in the winter. My two options were radiant heat in the basement under the kitchen or maybe to toe kick heaters. My other question is about the toe kick heaters I think I would have to go electric because the kitchen is already finished any thoughts? (I know I should have thought of it before I finished, but I didn't think it would affect the temp in the room that much).
Thanks again for the really helpful advice.
All rooms need heat. They have kickspace heaters for hot water boilers. It will be cheaper to run these then electric units. You can also run a zone of radiate heat under the kitchen floor by attaching the pex tubing to the underside of the subfloor and then insulating those bays.
Ron
Old 02-14-2011, 07:28 AM   #17
pjm
Ron thanks for the reply I was thinking electric because I'm not sure how I'm going to get a hw line to the kick space heater. I'll have to talk to my plumber about it and see if he can get what I need done. I'm leaning towards the kick space heaters after all the suggestions and advice.
Thanks to all of you.
pjm is offline   Reply With Quote
Old 02-14-2011, 09:34 AM   #18
Just size the heating elements, whatever they are, to the room size. You need to put in enough heat, not just heat.
Ron
Old 02-17-2011, 03:48 PM   #19
I would say to without a doubt insulation the ceiling the basement, the cold air has to go somewhere. If you use a insulation like open-cell it will not only keep the upper floors warmer, but it can also reduce noise transfer between the floors.
jsesic is offline   Reply With Quote
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
insulate inside basement closet? qchawkfan Building & Construction 2 01-08-2010 09:20 AM
unfinished basement ceiling major holes pictures included stefonroman HVAC 4 03-02-2009 05:26 PM
Patching unfinished basement ceiling? Pictures included stefonroman Building & Construction 2 03-02-2009 12:31 PM
Arch ways, columns and ceiling drops - basement cobase Building & Construction 3 09-01-2008 03:21 PM
