Should I Do A Full Jamb Or A Part Jamb For This Hole? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree8Likes
Old 05-24-2019, 09:40 AM   #1
Rewards Points: 192
Should I do a full Jamb or a part Jamb for this hole?
Hi there,
So this is the middle post of a wall, probably the most important one. Someone drilled the hole but drilled too big, which is almost about 1/2 of the whole depth of this post.
I'm in LA and I want my posts to be strong enough for earthquakes, Some people suggests me to put a jamb into that hole, as it could be worse to replace the whole post (which will loosen the top plates even more)
So I can :
1. Make a wooden jamb about the exact same size of this hole , and put it in, and re-drill another hole for wires.
2. Make a wooden jamb about maybe 1/2 of this hole, and put it in, so no need to drill another hole as the other 1/2 is good wires.
Which will make it structurally stronger?
Sorry: please turn your head 90 degree to the right when you look at these photos.
rockman413 is offline   Reply With Quote
Old 05-24-2019, 10:41 AM   #2
Rewards Points: 6,643
Re: Should I do a full Jamb or a part Jamb for this hole?
If that is one stud out of however many are placed 16" apart I would drill a new hole in the center of the stud to meet elec code and safety.
If it makes you feel better add a 2 foot slab of 2x4 to one side of the notch, secured with construction screws.
ZZZZZ likes this.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Old 05-24-2019, 11:17 AM   #3
Rewards Points: 192
Without putting a new jamb to fill the overly drilled hole?
Old 05-24-2019, 11:28 AM   #4
ZZZZZ's Avatar
Rewards Points: 1,618
I would go a step further and sister the 2x4 along the entire height of the post. And a bit of construction adhesive along with the screws wouldn't hurt. (A full 2x4 is cheap.)
Then drill the appropriate size hole for the wiring though the 2x4 and into the existing over-sized notch hole. No need to plug the notch.
georgemcq likes this.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Old 05-24-2019, 11:36 AM   #5
Super Moderator
joed's Avatar
Rewards Points: 22,654
Looks like you have more than on that is a problem. I would sister new 2x4 stud beside the notched ones and drill holes for the cables. Under the electrical code those notches are not correct.
ZZZZZ likes this.
Old 05-24-2019, 11:59 AM   #6
Now that the picture is right side up I see it is more than one stud so I would sister first then drill.
Colbyt
Old 05-24-2019, 12:11 PM   #7
Rewards Points: 192
The reason I'm concerned to sister with the 2 2X4 at the both side of this post is:
It's an old wall, and the bottom woods, some part of the woods are missing. I kinda worry that if I sister with another 2 2X4, it'll be more heavier than what the bottom woods can handle especially some pieces of those woods are already missing (my contractor said it's ok not to , probably also too hard to put in new woods inthose bottom holes) and may actually weaks these wall if there's earthquake.
Old 05-24-2019, 12:13 PM   #8
retired framer
Rewards Points: 14,030
slip in the steel to protect the wire and add another stud on the flat beside that one.
https://www.homedepot.ca/product/ibe...-25/1000408042
Domo likes this.
Do not use flat bottom gables with scissor trusses.
Old 05-24-2019, 12:22 PM   #9
ZZZZZ's Avatar
The weight of a 2x4 is negligible compared to any load that the wall is carrying from above.
But if the bottom plate of the wall is also damaged, that's a concern that needs to be addressed first.
Old 05-24-2019, 02:04 PM   #10
hkstroud's Avatar
Rewards Points: 5,548
Purchase stud shoe. Straighten out one leg of it. You now have an L shape bracket. Slip bracket between stud and drywall. Screw one leg of bracket (the one you didn't straighten) to one side of the stub. Using pliers bent the other leg toward the stud as much as possible. Then using C clamp bend the leg flat to side of stud. Fasten with screws.
Stud will be as strong as it ever was if not stronger and cable will be protected.
ZZZZZ likes this.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 05-24-2019, 07:47 PM   #11
ZZZZZ's Avatar
nice. I hadn't see that kind of bracket before.
A 2x4 to sister the post probably costs less.
Nealtw likes this.
Old 05-28-2019, 09:24 PM   #12
Rewards Points: 192
This is what I'm concerned about sistering 2 2X4 at the sides of the post. See my arrows showing where the bottom plates are missing. (2nd photo showing the right part of the same wall) Because of thus missing plates, I'm concerned if I put 2 more 2X4 posts, it would be too heavy in the extreme cases such as earthquake.
That's why I'm a littlle more leaning towards what the engineer told me: jamb. I'm not sure if I should put a whole jamb to jamb the whole hole, or only half of the hole so the other half can be used to run the wires.
Should I do a full Jamb or a part Jamb for this hole?-img_6860.jpg   Should I do a full Jamb or a part Jamb for this hole?-img_6861.jpg
Old 05-28-2019, 09:36 PM   #13
retired framer
Carry on and ignore those bits that are missing. Your bracket is pulling the stud down tight, and even if there is a space there you won't bend the bottom plate into it.
Old 05-29-2019, 06:11 AM   #14
Rewards Points: 192
Which part is the bracket you mean? what do you mean by dend the bottom plate into it? you mean to insert the wooden plate into the holes?
So to carry on, should I use 2 2X4 to sister the main post? Or just to fill the jamb?
Old 05-29-2019, 06:22 AM   #15
retired framer
In these two pictures here, I do not see anything that needs more attention.
Should I pay full or part Home_DC HVAC 6 07-16-2012 06:57 PM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 09:24 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
