Shed Roof Over Entrance - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-17-2015, 09:01 AM   #1
Rewards Points: 93
Hello All,
I have included a picture and I'm looking for input for the best approach to build a shed style roof over the basement entrance. This winder was brutal. We had 5 feet of snow and drifts stacked in this corner. At times I could not get into the basement when it was frozen.....
I'm not sure if I should build a header, or build a box to fit the corner to support my rafters. The kitchen window is shown on the upper left, and a bed room window on the wall straight ahead. I was going to 45 a 4 x 4 support back to the concrete foundation. I'm just unsure what the best approach is to build the rafter support system. In total it will be 8' long by 4' wide
johnpma is offline   Reply With Quote
Old 06-17-2015, 11:38 AM   #2
Rewards Points: 2,654
The corner is plagued with eddy currents and all it takes to prevent them in that location is a section of fence similar to the partial fence panel in the photo but would only need to be about 4 ft. tall. In fact a shed roof could make it worse.
It would need be in close proximity to the house on the windward side and could have a 4-6 ft. gap and stand off of the leeward wind corner ( a walk through ) running a couple of feet beyond that corner.
If it were built with portability in mind it could be taken down or moved during months other than winter.
Old 06-17-2015, 11:55 AM   #3
Rewards Points: 93
This is along the lines of my thinking
Old 06-17-2015, 12:28 PM   #4
That's a real nice looking roof and they make an entrance more pleasant when it's raining but it just won't stop the snow drifting in the corner.
Another serious consideration is how it is to be attached to the original structure. If strict guidelines aren't followed pertaining to flashings the end result is usually rotted walls.
installing a metal roof on a shed will02 Roofing/Siding 15 04-08-2014 03:41 PM
Ceiling joists with shed style roof? agent008 Building & Construction 3 09-29-2013 02:30 PM
add shed roof to gable roof lucy1 Roofing/Siding 0 10-30-2011 09:31 PM
Shed roof addition & insulation qustion radgumbo Roofing/Siding 2 12-06-2010 06:33 AM
Shed Porch roof tying in... my5sons Roofing/Siding 7 10-27-2009 09:19 PM
