Shed Floor Replacement? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-30-2009, 02:06 PM   #1
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
I had a bee hive and had to cut the OSB floor. The shed is built on dirt that sees a good amount of moisture in a hot climate. I was thinking about removing some of the dirt to give more airflow and possibly install some hidden storage space. The shed is built of 2x4's with T-111, about 9'x15', with a 10' slanted roof.
What should I replace the OSB with and any other suggestions? I was thinking about putting vinyl tile down in the past, but figured it could be a waste of time.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 05-30-2009, 02:47 PM   #2
Rewards Points: 1,016
How about pressure treated plywood. And yes, if you can get the dirt away it would be a good thing I would think.
Old 05-31-2009, 09:39 PM   #3
Fixer-'til-broker
Rewards Points: 262
Thanks.
PT plywood (not sure of the rate code), CDX, and the like are too expensive and most of the floor is still good. So I think treated OSB wins this time.
Maybe I'll pour a concrete box between the skids and put some drainage pipes or something underneath. I don't want termites! Gotta keep a squirrel out of there now that the bees are gone - the beekeeper and I agreed that the squirrel burrow is what brought the bees. I haven't seen the bugger in a while.
Old 05-31-2009, 09:43 PM   #4
Were they honey bees?
OSB will rot eventually exposed to moisture
My last shed the floor fell aprt, not sure how old it was
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
shed power suggestions rsriverrat Electrical 36 12-29-2008 12:42 PM
Help with wiring in shed sandyman720 Electrical 1 06-25-2008 11:11 AM
Shed Wiring bcdal Electrical 12 03-26-2008 04:51 PM
