Sheathing And Fascia - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-12-2009, 08:00 PM   #1
Sheathing and Fascia
I'm building a shed. The rafters are 24" OC, with a "tail" to form a eaves.
What I'm not sure about is:
1) Should I attach the Fascia board before or after I install the roof sheathing?
2) Should the sheathing go over the fascia board (or stop at the end of the tail)? If not, I assume the paper and shingle would overlay the fascia.
I'd like a balance of "doing it right" and not spending an extraordinary amount of time on it
Thanks in advance.
ManCard is offline   Reply With Quote
Old 07-12-2009, 08:12 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,916
You should extend the sheathing the 3/4" beyond the tails or if there is a rough fascia, beyond that.
I forgot about the fascia when I put the roof sheathing up over my portico and attached the fascia to the tails and sheathing. It didn't really matter.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 07-12-2009, 08:17 PM   #3
I put the fascia up 1st
Then the roof sheathing over that
Drip edge/gutter apron covers the area where they connect
Old 07-12-2009, 10:42 PM   #4
Registered User
Rewards Points: 526
Fascia first, break sheathing middle of it. Paper over fascia so it sags with age and hides ply. Roofing 1 knuckle past fascia. Be safe, G
Old 07-13-2009, 01:04 AM   #5
"One knuckle past the fascia" Now, that's what I call old school!!
Mop in Hand is offline   Reply With Quote
New roof and Sheathing - Install new fascia before or after? hartkem Roofing/Siding 2 06-01-2009 01:12 PM
Fascia Material kz6k9q Roofing/Siding 8 04-18-2009 11:57 PM
Filling skip sheathing MJJ Roofing/Siding 3 06-13-2008 10:14 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
Roof sheathing overhang on fascia Clutchcargo Roofing/Siding 7 08-23-2007 02:02 AM
