Sewer System Question - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 02-17-2018, 01:40 PM   #16
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,442
Re: sewer system question
Originally Posted by Gregsoldtruck79 View Post
Pretty good observation but "questionable" .
It's bad, but legally??
Not the right thing to do and I myself may have a hard time doing so.
I don't know though. If panic about having a worthless piece of property set in, how would I allow my morals to influence me? Tough call.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 02-17-2018, 04:05 PM   #17
ZTMAN's Avatar
Rewards Points: 386
If the city won't help, any possibility to disconnect and put in your own septic system?
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 02-17-2018, 05:52 PM   #18
123pugsy's Avatar
Sounds like a good fall back plan so all is not lost.
Old 02-17-2018, 06:15 PM   #19
Super Moderator
joed's Avatar
Rewards Points: 29,542
That is not usually allowed if sewers are available. It would also likely be worse when it rains even less.
Msradell likes this.
Old 02-18-2018, 03:29 PM   #20
Mike Milam's Avatar
Rewards Points: 280
In the Commonwealth of KY, the statute of limitations on disclosures statements is ten years.
If the person has not lived there longer than ten years, I would start by requesting all records from the sewer provider to see how many times they had been called and what the calls were for and the resolution was each time. If there were calls made regarding this issue and the last homeowner had contacted them, that's (in my opinion) an omission on the disclosure statement.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is online now   Reply With Quote
Old 02-18-2018, 10:03 PM   #21
Rewards Points: 4,796
Epa.?
ron45 is offline   Reply With Quote
Old 02-22-2018, 08:34 PM   #22
Rewards Points: 54
Where I live, we have a similar issue, but more widespread. The sanitary sewers back up and flood basements. The problem here is infiltration. The old clay pipes crack, break and the storm/downspouts infiltrate into the sanitary system. This overwhelms the treatment plant and they have to discharge untreated waste into our freshwater lake. (They are currently upgrading our treatment plant to the tune of $100 million).
In my city, whenever you sell your house, you are required to have a dye test. They test your system all the way to the street to make sure there is no infiltration. If there is, you have to fix it. Average cost... $8000- $10,000. This has been in place for some time. My first home I bought in 1990 failed, but it was in the "city right-of-way". I asked when they were going to fix it. They said "when we do the whole street".
Flashover is offline   Reply With Quote
Can I test my sewer system for leaks myself? noone Plumbing 50 11-05-2016 02:15 PM
Sewer Back Up/ Pipe Relining Question newbinca Plumbing 9 05-10-2013 01:23 PM
Question about install Allure flooring system over linoleum dgeorge Flooring 8 01-08-2011 03:40 PM
Question about septic system...... randalg Plumbing 7 03-21-2008 02:43 PM
