Setting Lvl Beam Up To Support 12 Feet Opening - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-06-2014, 10:36 PM   #1
stevergee's Avatar
Rewards Points: 73
Setting lvl beam up to support 12 feet opening
Question - Does it make sense to set the beam directly against the joist and stud that are cut - or should I install a 1 by board in place first ?
The center wall of course had rough cut 2 by 4 underneath the overlapping joists and that beam was installed directly under that.
This wall opening will give me 12 by 6 expansion to the kitchen and it will have its own vaulted ceiling feature .
So the idea would be give the opening to this area an even higher clearance than the the center beam. But just wondering if it would be kosher to install the directly or put a plate board in first
stevergee is offline   Reply With Quote
Old 09-06-2014, 10:39 PM   #2
Framing Contractor
Rewards Points: 76
Add ing the 2x4 plate may give you something better to nail into. Trying to toe nail through the lvl into the joists may not be easy. You could face nail the 2x4 to the joists and then toe nail the lvl to that plate.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
stevergee (09-06-2014)
Old 09-06-2014, 11:00 PM   #3
stevergee's Avatar
Rewards Points: 73
I would not actually use nails - but rather 3 inch star bit lag screws that have the small head and would sink into wood beyond the surface - so it is easy enough to stitch those through the lvl - no problem at all
Wood is wood
Old 09-07-2014, 12:23 AM   #4
stevergee's Avatar
Rewards Points: 73
It definitely be better to have a plate board to face nail into the joists - I may compromise and use 1 by 4 as the plate
Old 09-21-2014, 04:46 AM   #5
stevergee's Avatar
Rewards Points: 73
The beam is finally up and in
The Following User Says Thank You to stevergee For This Useful Post:
hand drive (09-21-2014)
can my floor support my new fancy beam?? rlc05n Building & Construction 3 09-18-2013 10:13 PM
new member with question on support beam pointer80 Building & Construction 7 02-02-2012 10:23 PM
Triple 2x10 beam has twisted WillK Carpentry 11 12-28-2011 12:50 PM
Best method to support new load-bearing beam Pittsville Building & Construction 7 06-10-2011 02:12 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
