Setting Flagstone On Top Of A Hearth - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 01:31 PM   #1
setting flagstone on top of a hearth
need some advice. Just finished applying stone veneer to my fireplace and I'm ready to put the flagstone 87x24x2 on top of my existing brick hearth. Proper or best installing advice would be appreciated.
fixeruper is offline   Reply With Quote
Old 10-30-2010, 10:51 PM   #2
Rewards Points: 5,348
You need to post a picture to get worth while advice.
Ron
Old 10-31-2010, 12:14 AM   #3
Rewards Points: 83
I'm actually doing the same thing right now. The new hearthstone has to be even with the firebox floor, so I started out by chiseling away the top layer of brick and mortar. I'm almost done with that now. Next I'll make a form around the hearth and a screed, and use type S mortar to make a nice flat base. Like you, my hearthstone will be 2" thick, so I'll make sure the base is down about 2 1/4". After that sets, I'll spread mortar with a notched trowel and set the hearthstone.
cumak is offline   Reply With Quote
Freezer not cold enough at "normal" setting... skipjack Appliances 2 02-01-2010 04:10 PM
Least expensive Programmable Thermostat for home with automatic vacation setting Studly HVAC 2 12-15-2009 08:18 AM
Fireplace facelife - needing hearth advice louiejr Building & Construction 4 11-25-2009 06:57 AM
Floating floor to hearth transition Y2Kotik Flooring 3 05-21-2009 11:50 PM
Please Help with Fireplace Hearth Planning BobnSofi Building & Construction 1 02-18-2008 07:26 PM
