Seeing Studs Thru Sheet Rock - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 05:16 PM   #1
Question
seeing studs thru sheet rock
I have a house that is about 7 yrs old. It has vaulted ceilings. I can see the stud shadows through the sheetrock and paint. It almost looks like dirt shadows. What would cause this....some say to much moisture in the house....others say check the insulation...My contracter is out of the country for the next year. What can I do, who do contact to start with?
fieta is offline   Reply With Quote
Old 03-08-2010, 05:41 PM   #2
Rewards Points: 582
Sounds like pattern staining, which is dust gathering on the colder studs inbetween the warmer insulated area.
http://www.buildingpreservation.com/Case%205.htm
stuart45 is offline   Reply With Quote
Old 03-08-2010, 06:16 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 32,352
It is dirt shadows cause by cold studs. The studs act as a thermal bridge. Moisture condenses on the cold stud and dirt sticks to it.
Old 03-08-2010, 06:55 PM   #4
PHB Construction LLC
Paulie's Avatar
yep, I vote for thermal bridging. Your builder must be doing pretty good to take a trip out of the country for a year. I'm lucky to go for a weekend trip up north.
Paulie is offline   Reply With Quote
Old 03-08-2010, 07:09 PM   #5
Retired Moderator
Rewards Points: 7,174
Do you burn candles in the house? Wood burning stove ? smoke ?
That condition is sometimes called soot staining. People who burn candles experience this.
The 'thermal bridging' that all the others have described is like a magnet to air born soot.
Might just be time to paint.--Mike--
Old 03-08-2010, 07:11 PM   #6
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
Would caulking the stud bays help the OP with this problem?
brons2 is offline   Reply With Quote
Old 03-09-2010, 06:19 AM   #7
Retired Moderator
Vaulted cielings just do that----
Soot staining is going to happen on vaulted ceilings due to the colder areas caused by the colder studs(rafters).
It would be impractical to isolate the colder framing from the drywall.
There are ways to pull this off ,of course, but a sensible person would limit the soot in the air or just repaint.
--Mike--
Old 03-09-2010, 06:26 AM   #8
i have this from my fireplace on my vault rafters but it seems to be leaveing a film over everything. whe you wipe down walls or vanities it comes up black. my house is not that tight does this indicate downdraft problems
The older I get the better I was
Old 03-09-2010, 06:47 AM   #9
Retired Moderator
TPOLK--Sounds like you do have a bit of a leakage problem with the stove.
I've been heating a lot with wood for about 8 years--I get some sooting on the vaulted ceiling -but not to bad, I'm over due for a paint job--I don't mind the painting but I hate working on my own house.
--Mike--
Back Splash Tile Over Old Sheet Rock? Stcrosby Remodeling 3 01-03-2010 12:46 PM
Sheet rock (1/4") in trailer house sagging chrissygarden Building & Construction 4 08-19-2009 10:53 PM
Sheet Rock UpComingBuilder General DIY Discussions 7 12-19-2008 12:22 AM
Wall studs showing through sheet rock js1971 Remodeling 7 09-11-2008 05:45 AM
Painting over messed up sheet rock. emilyiam Painting 2 03-24-2008 04:00 PM
