Securing Partition Wall On Subfloor In Basement? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-26-2010, 10:29 AM   #1
Securing Partition Wall on Subfloor in Basement?
I am finishing my basement. I have put down a plastic membrane called Platon, and used ¾ inch T&G OSB as a subfloor. Should I just attach the walls to the subfloor or should I use Tapcon’s and go all the way to the concrete?
On Iowa! is offline   Reply With Quote
Old 02-26-2010, 05:38 PM   #2
Drywall contractor
Rewards Points: 1,114
According to the installation instructions on the Platon website, "non load bearing walls may be framed on the subfloor". Your subfloor "(minimum 7/16" OSB)" should be "fastened to the concrete around room perimeter"". Sounds like you don't want to penetrate the barrier if you don't have to....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Basement Wall rainking45 Remodeling 1 09-18-2009 01:34 PM
Need unbiased help on finishing basement - Dry wall or panel system? mmr1234 Building & Construction 6 08-29-2009 10:30 AM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 01:38 PM
Finishing old basement force4ormore Building & Construction 1 12-29-2008 02:48 PM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 09:16 AM
