Second Floor Over A Masonry House - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Rafacacho
  • 1 Post By carpdad
Old 09-02-2018, 08:51 AM   #1
Rafacacho's Avatar
Rewards Points: 22
Second floor over a masonry house
Hi, just move to a new house. It has a flat roof ( concrete) because it was supposed to have a second floor (masonry).
Question is, I am going to frame the second story, what size of floor joist should I use? 2x10, 2x8, 2x6? They go flat right over the roof, that is actually like a slab.
Enviado desde mi Redmi 5 mediante Tapatalk
Rafacacho is offline   Reply With Quote
Old 09-02-2018, 09:01 AM   #2
retired painter
Rewards Points: 844
Re: Second floor over a masonry house
Check with your local bldg dept - they're the ones that will need to approve the plans and inspect the framing.
mark sr is offline   Reply With Quote
Old 09-02-2018, 09:07 AM   #3
Rewards Points: 7,072
Being flat I don't see that they are providing any support.
Your location would help us to know what methods your are following.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 09-02-2018, 09:08 AM   #4
Guapo
Rewards Points: 11,950
They are going to want at least 2x8s. No matter what, you will have to present plans.
Guap0_ is offline   Reply With Quote
Old 09-02-2018, 09:26 AM   #5
Rafacacho's Avatar
Rewards Points: 22
Bud
The joist doesnt go flat, what I was trying to say is that there is no span at all, because the joist is supported along its full lenght. I live in Argentina, theres no inspector or building dept.
Old 09-02-2018, 09:27 AM   #6
retired painter
Rewards Points: 844
How is this flat roof constructed? How much load is it capable of carrying?
Old 09-02-2018, 09:30 AM   #7
Guapo
Do yourself a favor. Hire an architect.
Old 09-02-2018, 09:46 AM   #8
Rafacacho's Avatar
Rewards Points: 22
Able to hold a brick second story, strong enough to hold a frame building.
Old 09-02-2018, 12:47 PM   #9
retired painter
Rewards Points: 844
That isn't really an answer. Brick would be supported by the exterior first floor walls not the flat roof. IF the roof has enough structure you wouldn't need more than a 2x4 joist but if it's not - then you need whatever size joist is required for the unsupported span [just like the roof wasn't there]
Old 09-02-2018, 01:01 PM   #10
Rafacacho's Avatar
Rewards Points: 22
Exterior wall are 30 cm (+/- 12 inches), interior half that size, all brick, with columns and beams of concrete with steel bars. Where there is not wall in the first floor, there is a concrete beam. It was meant to hold a second story of brick construction. Support is not an issue, but I want a solid subfloor and the bathroom tubes needs to go trough. Thanks for your help.
Old 09-02-2018, 01:08 PM   #11
retired framer
Rewards Points: 1,540
If you have to core holes in the floor for plumbing anyway, just use the concrete floor for a floor.
Old 09-02-2018, 08:32 PM   #12
Rafacacho's Avatar
Rewards Points: 22
I want to put insulation, but now that you point that, I see that my original question is stupid. 🤦🏽*♂️ Thanks
Nealtw likes this.
Old 09-03-2018, 07:42 AM   #13
Rewards Points: 260
North american buildings are different from argentina. What are the differences? Concrete footings and wall or brick only walls on some kind of footing? If the roof was built originally as a PLANNED floor, why not use it as a floor? Why now rethinking the floor? What is the span of the planned floor joists?
All of these things would require you to see a local engineer or a builder. Don't assume anything just because they are there. Not to offend, but it is always possible to consider that your roof is a roof because the builder cheated on the reinforcement and the material for the planned floor and abandoned the idea of using it as a floor than taking the liability. If that roof is not built to be a floor, you don't want to put lumber on them as if the slab is load bearing all the way through.
How was the roof protected? If it is bare concrete, rebars and such could have rusted, even if argentina, I think, is fairly dry country.
mark sr likes this.
carpdad is offline   Reply With Quote
Old 09-04-2018, 07:01 PM   #14
Rafacacho's Avatar
Rewards Points: 22
Concrete footings, with concrete post and beams, then the gaps sre filled with bricks.
I want an elevated floor, because it is more comfortable and I want to put insulation between the floor joist.
There is no actual span, because each joist will rest on the concrete floor all the way.
The roof has a "false" gable over it. Its been use as an attic to store old furniture
There is an architec involved but they know nothing about framing. You can see his work in some of my others treads.
Old 09-04-2018, 08:26 PM   #15
retired framer
I would do this with foam and floating plywood with the T&G glued.
Questions on Construction of my House: Built in 1980's, questioning structural design ejumps Building & Construction 4 03-05-2016 06:55 PM
water mitigation around house tnprogrammer Building & Construction 4 02-22-2016 04:10 PM
Pros please help - what method attach porch roof to brick veneer dinoburger Concrete, Stone & Masonry 6 08-02-2015 11:57 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 09:58 PM
