Second-floor Deck On Piers - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-03-2014, 06:55 PM
Rewards Points: 186
Second-floor deck on piers
Be honest: is this safe?
I swear they put posts in piers for this. You all know what I'm talking about:
I just bought a side lot. I'm not allowed to build anything permanent; I'm considering wrapping the whole house with a deck. The porch stands about 6 feet (basement is ~2 feet below grade?), so a first-floor deck would be 6 feet raised from the ground. I, however, am interested in a second-floor deck or a two-story deck.
A deck is not a permanent structure. Posts can be removed readily. Likewise, a shed on pier blocks can be pulled off by a truck, allowing removal of the piers and gravel. A poured foundation and brick building is not legal for the first 10 years.
On one hand, I like this idealized 6x6 or 8x8 post foundation footed into gravel (shouldn't that provide frost resistance, due to gravel motility?) holding up a second floor or two-story deck. On the other, could you imagine the supports shifting? A deck collapse can cost thousands in property damage, and lead to injury or death.
If you can't explain why, then you don't know what you're talking about. I'll keep asking until I find someone who does.
bluefoxicy is offline
Old 09-03-2014, 07:09 PM
Rob
Robpo's Avatar
Rewards Points: 826
I have seen a lot of decks built with just the piers in Tahoe. I don't know if they are safe but if your frost level is not deep it might be okay.
Robpo is offline
Old 09-03-2014, 07:19 PM
Rewards Points: 186
Tahoe? You mean the lake?
Is this like pahoehoe?
I'm trying to maximize available space, but don't want to build something unsafe.
Old 09-03-2014, 07:24 PM
Rob
Robpo's Avatar
Rewards Points: 826
Yes, The Lake in the Sky.(meaning of Tahoe)
Don't know what pahoehoe is.
Never heard of one falling but I would keep an eye on it.
Robpo is offline
Old 09-03-2014, 07:30 PM
Rewards Points: 186
Was a joke. Pahoehoe is a type of basalt lava. I thought you were indicating a material gravel to seat piers in.
Methinks I can't freestand this anyway. It would be too top-heavy. So much leverage without screwing it to a wall (the wall there is concrete) would allow for ripping the posts out, unless piled deep in the ground. Deep-set lumber will rot (water table), and stress will break wood anyway. I would need to fasten the deck to the building, or buttress it (which is unreasonable).
Fasteners provide opportunity for water ingress and freezing.
Old 09-03-2014, 07:41 PM
Rob
Robpo's Avatar
Rewards Points: 826
I agree there would have to be a ledger lagged to the wall. I assumed that.
Robpo is offline
how to veneer brick porch piers with stone pcshay Concrete, Stone & Masonry 12 06-23-2014 08:51 PM
Piers in crawl space dfiddler General DIY Discussions 2 07-30-2013 07:23 AM
Rebar in poured concrete piers montana_bound Concrete, Stone & Masonry 0 09-19-2012 12:10 AM
Building on piers & pressure treated posts, or just concrete piers? TinaRap Building & Construction 13 05-08-2010 04:00 PM
piers under a new addition shama144 Building & Construction 2 10-22-2008 01:19 PM
