Seam Between Kerdi Board And Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-09-2017, 10:23 PM   #1
Rewards Points: 270
Seam between Kerdi board and drywall
I'm installing Kerdi board in a shower and it will butt up against drywall. I was wondering what I should use in between the drywall and board. Should I tape and mud it or just caulk the seam? I'll be tiling the kerdi and then just painting the drywall. Thanks
joeg679 is offline   Reply With Quote
Old 09-10-2017, 07:24 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 626
Re: Seam between Kerdi board and drywall
Generally your finish tile, whether bull nose or Kerdi strip will overlap onto the sheetrock, forming a seam of its own. If you plan on finishing the crack, tape and mud it like any other sheetrock joint, and bring your tile as close as possible to that seam.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 09-10-2017, 08:06 AM   #3
Rewards Points: 898
I would probably use the kerdi band and install it as directed by Schluter. Make sure the joint is over a stud.
BIG Johnson is offline   Reply With Quote
Install cement board over drywall? aklindow Drywall & Plaster 1 03-07-2015 09:50 PM
What to do with cement board to drywall seam? Arsinek Kitchen & Bath Remodeling 10 04-24-2014 04:09 PM
Backer board to drywall seam issue mojo1122 Tiling, ceramics, marble 1 05-02-2013 09:49 PM
Cement Board or Drywall or Both Calvo Remodeling 6 03-07-2012 12:24 PM
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 09:29 PM
