Sealing PT Wood Cuts? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-29-2016, 08:50 AM   #1
Sealing PT wood cuts?
I've looked a lot online and there seems to be a huge difference of opinion on whether to seal cut ends of pressure treated wood.
I can't find any local stores that even carry it in stock.
What do you guys think?
MW5260219 is offline   Reply With Quote
Old 08-29-2016, 09:09 AM   #2
Civil Engineer
Rewards Points: 5,246
Re: Sealing PT wood cuts?
You can't find any stores that carry PT lumber in stock? That seems odd, every BB lumber store sells it.
As to sealing the ends, you can certainly seal the ends with paraffin or similar wax seal products. Not sure how much it extends the life of the PT. I sealed the ends of my ipe deck boards using a paraffin based sealing product, there has been no deterioration in 5+ years, but then again there might not have been any without the paraffin.
Old 08-29-2016, 09:16 AM   #3
I meant I can't find any sort of PT cut sealer in stock anywhere.
There is plenty of PT wood available lol.
Do you know any brand names or products to seal the cuts?
Old 08-29-2016, 10:19 AM   #4
Rewards Points: 1,376
Rust oleum makes a product called wood life green preservative....or something like that. Walmart carries it in my area. Ron
ront02769 is offline   Reply With Quote
Old 08-29-2016, 11:44 AM   #5
Civil Engineer
I used Rockler Green Wood end sealer.
Old 08-30-2016, 10:56 AM   #6
Rewards Points: 297
Like yourself, I could not find it locally in stores. Ordered from Amazon Prime instead. The "brown" color fades away and looks a little more natural than the green products. I used some cheap-o disposable chip brushes to apply it. Smells terrible, but that fades as well.
https://www.amazon.com/Products-3300...per+brown+wood
red92s is offline   Reply With Quote
Old 08-30-2016, 01:32 PM   #7
Rewards Points: 1,042
I's still use paraffin on the ends.
Canarywood1 is offline   Reply With Quote
Old 08-31-2016, 12:40 AM   #8
Rewards Points: 122
I've used lot of PT lumber and never sealed the cuts with paraffin or waxy stuff. I've had good results using Wolman CopperCoat Green Wood Preservant. It is a liquid that you brush or mop on the cut ends. I also swabbed it in any holes drilled in or through the lumber. It's available at some Home Depot stores and lumber yards and online. It is available in formulations for above ground use and ground contact.
rander101 is offline   Reply With Quote
Old 08-31-2016, 10:31 AM   #9
Looks like Amazon it is.
Wanted to buy the ground contact woodman but it's pricey on Amazon
Thanks again
Sealing 5/8" holes in wood air return pex006 HVAC 3 01-12-2014 10:56 PM
Multitool wood blade cuts sheetrock? miamicuse General DIY Discussions 7 10-17-2013 01:31 PM
Replacing Windows in home with LOTS of wood DomiFamily Building & Construction 0 05-14-2013 11:38 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
sealing a very old wood deck browneyesbloo Building & Construction 6 09-23-2008 09:47 PM
