Sealing A Gap In The Wall With A Copper Heating Pipe - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-07-2018, 12:50 PM   #1
Rewards Points: 90
Sealing a gap in the wall with a copper heating pipe
Hi
Hope this is in the right subforum.
I have a copper heating pipe (hot water type) coming through the wall (sheet rock) in my apt, and I am trying to close up the hole best I can. I care nothing about aesthetics, as it will not be visible.
I am leary of using silicone, as even if I find out what the heat tolerance is, I do not know how hot the pipe gets. Anyone know? Or is the correct answer to that... it depends?
Any ideas on what I can use? something like either of these?
https://www.homedepot.com/p/3M-10-1-...-136/100390499
https://www.3m.com/3M/en_US/company-...4068993&rt=rud
Thanks in advance.
jhayat is offline   Reply With Quote
Old 07-07-2018, 12:52 PM   #2
retired framer
Rewards Points: 6,228
Re: Post
Did you have a question?
Old 07-07-2018, 12:53 PM   #3
Rewards Points: 90
Re: Sealing a gap in the wall with a copper heating pipe
Yeah - its in the post now. Having a terrible time trying to post here the past several days, so I had to do that peace meal.
Old 07-07-2018, 11:38 PM   #4
Rewards Points: 1,906
Get a two-piece escutcheon: https://www.homedepot.com/p/Everbilt...340C/205153761
ChuckF. is online now   Reply With Quote
Old 07-08-2018, 03:32 PM   #5
Rewards Points: 90
That worked - thanks!
Old 07-08-2018, 09:30 PM   #6
Msradell's Avatar
Rewards Points: 982
Originally Posted by ChuckF. View Post
It sounds like he's trying to create an airtight seal which those won't do. Either of the materials he cited in his first post would work just fine resealing around these pipes. Actually, even though he's afraid of using it a good silicone caulking would also work great. If it's a hot water system and not a steam system the pipes only get to be about 150-160 or so.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 09:58 PM
New posts and beams in crawlspace, post out of line WillK Building & Construction 1 02-26-2012 10:56 AM
Tiling vertical post kellyharris15 Flooring 12 02-22-2011 04:28 PM
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 10:01 AM
