Sanding Off Sealer - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-13-2010, 06:41 PM   #1
Sanding off Sealer
I have a new house with the basement floor sealed. I want to get rid of the sealer and stain the concrete and then seal it. Are there any ways to sand the sealer off the floor?
vimarshar is offline   Reply With Quote
Old 01-13-2010, 07:56 PM   #2
Remodeling Contractor
use a sealer remover or use a pressure washer. Sanding or grinding will modify the surface and show up poorly with a stained finish.
Old 03-01-2010, 09:39 PM   #3
There are all kinds of strippers that will work on acryliic sealers, just be sure to get one that is safe in an enclosed environment. I have stripped with an orange gel sealer, forgot the name and then it took a heated pressure washer to get the melted sealer off. It's a heck of a job. http://www.paverprotector.com/concrete-cleaning.html
PaverProtector is offline   Reply With Quote
metal left in hardwood floor sealer deetu Flooring 26 06-16-2012 07:29 AM
Hardwood Sealer David_in_MD Flooring 4 12-16-2009 07:05 PM
Car Painting and sanding h3llfir3 Painting 19 08-11-2009 09:44 PM
Car Painting and sanding h3llfir3 Automotive Repairs 1 08-10-2009 10:02 PM
Sanding marks.......will they show yummy mummy Building & Construction 9 07-23-2008 11:43 PM
