Is It Safe To Change To Board On Board Fence? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By woodworkbykirk
  • 1 Post By Drachenfire
Old 06-23-2017, 12:09 AM   #1
Rewards Points: 2
Is it safe to change to board on board fence?
I need to replace my side by side spruce fence. It has steel posts buried inside the retaining wall. I don't know how deep the posts were buried. Is it safe to replace it with board on board fence? I am wondering if the extra weight will cause burden to the posts and retaining wall. I like the look of board on board fence, but I will go with side by side if board on board might cause issues to the wall in the long run.
All suggestions and advice will be appreciated!
DustyBlue is offline   Reply With Quote
Old 06-23-2017, 05:21 AM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,528
Re: Is it safe to change to board on board fence?
Change away.
That's going nowhere.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 06-23-2017, 06:13 AM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
for the most part its not going to move but if its in a high wind region i woiuld gap the fence boards slightly so to allow air to pass between the boards so to reduce the chance of acting like a huge sail
joecaption and Drachenfire like this.
woodworkbykirk is offline   Reply With Quote
Old 06-23-2017, 06:33 AM   #4
Big Dog
Drachenfire's Avatar
Rewards Points: 4,388
You might also want to dress up the posts.
April Wilkerson did a 3-part series on YouTube with a similar fence. Segment 3 showed how she dressed up the posts.
123pugsy likes this.
Drachenfire is online now   Reply With Quote
Old 06-23-2017, 11:02 PM   #5
Rewards Points: 1,666
What is "gap the boards" slightly?? In board on board the pickets alternate sides and are set close to a board width apart. Ron
ront02769 is online now   Reply With Quote
Installing deck ledger board over foam board? RickT Building & Construction 9 04-27-2018 12:41 PM
Replacing Rim Board behind old Deck Ledger osubuckeye88 Building & Construction 11 10-26-2012 08:34 PM
new furnace control board same problems? jeremptucker HVAC 4 10-20-2012 02:11 AM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 10:41 PM
