?'s Concerning My Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2010, 06:47 PM   #1
?'s concerning my deck
my place was built in 2008, i have 2 decks, one at the front which is a second level entry. and the back deck is off my kitchen. my question is as follows... 1: it seems as if the main support 6x6 are just resting on concrete. and the wood looks like it is going to split in 2, there are cracks 3mm spanding over 3 feet long. i know this is not normal, but my builder says it is.... WHATTTT hahaha. 2: is there any likely hood of this deck falling over? i have a 1 yr old who is learning how to walk...and it concerns me a great deal. any help at all would be great.
my place is a 2 level condo unit, and these decks in my eyes, are not up to code, however they did past inspection, so im told.
TIA
p.s i do have some pix if you want to see what im talking about
inknmetal is offline   Reply With Quote
Old 06-16-2010, 06:55 PM   #2
Rewards Points: 2,712
Pictures would help a lot.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
oh'mike (06-16-2010)
Old 06-16-2010, 07:45 PM   #3
here is a pic....
here is a pic.... this is a 4x4 that supports the stairs
close up pic
Old 06-16-2010, 07:48 PM   #4
Cracks in PT are fairly common, I'd say the Norm
I never post a post directly on cement or in cement
That doesn't look like it is attached to the cement at all, are the other deck posts ?
Old 06-16-2010, 07:55 PM   #5
thx for reply... i understand cracks are norm... but some of the cracks span from top to bottom.. and the 2x10 supports under the stairs are cracked on both sides at the same place... is that normal?
TIA
Old 06-16-2010, 08:05 PM   #6
Very hard to state anything without seeing it...more pics would help
I have seen cracks like the 1st pic, I have never worried about them
Old 06-17-2010, 09:32 AM   #7
Rewards Points: 306
If movement is a concern from slippage on the concrete you can screw and angle bracket into the post and into the slab.
moneymgmt is offline   Reply With Quote
Old 06-18-2010, 10:44 AM   #8
Concrete & Masonry
Rewards Points: 518
I'd be more concerned about the concrete if it was that new!
Unless, of course, they were going for the exposed aggregate look................
jomama45 is offline   Reply With Quote
Deck Addition - Floating to Attached Foundation eemichael83 Project Showcase 15 08-22-2010 09:40 PM
Floating deck questions DIYguy2000 Building & Construction 6 04-23-2010 10:59 AM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
