Running Coxal Cable Into Gabel. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-26-2017, 11:48 AM   #1
Rewards Points: 76
Running coxal cable into gabel.
Hello I'm setting up my antenna this week d and I'm trying to run my cable into my attic with our having to drill to many hole in roof. I was thinking of installing antenna on the edge of the roof other side of electric mast. And run the coxal cable into the gable window though the attic and down the wall into box. The drip line would be right at the gable window. Is that a good entery point.
Pic is attached to show location of install.
Sent from my SM-J327P using Tapatalk
charles3526 is offline   Reply With Quote
Old 10-26-2017, 12:13 PM   #2
Idiot with tools
Rewards Points: 106
Re: Running coxal cable into gabel.
why not just poke a small hole in that vinyl soffit and feed it into the attic from there?
a912 is offline   Reply With Quote
Old 10-26-2017, 12:24 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 30,526
Through the gable vent will fine. That is how I did mine.
Old 10-27-2017, 07:12 AM   #4
Rewards Points: 76
Thank you through the vent it is would like to do the easiest job with out drilling ant more holes in siding. I can put the drip loop right before it enters the vent correct?
Old 10-27-2017, 09:51 AM   #5
Super Moderator
joed's Avatar
Drip loop is fine. You can even paint the cable if you want to disguise it.
Old 11-06-2017, 07:32 AM   #6
Rewards Points: 6
Thanks guys for all the information I'm going to install this week looking for a good week of weather so the sealant can try that I'm going to use on the screws and the holes
chris246810 is offline   Reply With Quote
Running cable under joists next to walls? Toller Electrical 4 08-22-2015 10:04 AM
Running audio cable under floorboards cue8chalk Home Theater 5 04-22-2015 09:13 AM
running cable in the ceiling sdieddie Home Theater 3 03-10-2013 11:14 AM
Running data cat5 cable in walls fdmillion Electrical 2 01-17-2013 08:15 PM
Running Ethernet and Coax Near Power Cable rjschwar Electrical 11 12-27-2009 04:44 PM
