Running Cables Near Fireplace - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-31-2016, 12:20 PM   #1
Rewards Points: 18
Running cables near fireplace
I'm looking to install a TV over the fireplace (we don't use the fireplace) and have a question on how to run the cables. What are the chances that if I cut a hole behind the picture, I can fish some down the wall to the basement (at the left side of the clock). Thanks
Shelby2098 is offline   Reply With Quote
Old 12-31-2016, 02:26 PM   #2
Rewards Points: 382
Re: Running cables near fireplace
Do you have a pic of basement ceiling where you are hoping the cable will enter the basement?
Erico is offline   Reply With Quote
Old 12-31-2016, 03:03 PM   #3
Rewards Points: 18
I just looked and I don't think it will work regardless. In the crawl space, the section that I would need to come up, is over the exterior wall and there is no room to get in there and drill a hole. I measured from a conduit that feeds a outlet to the wall and I have 25", when I measure that upstairs, it puts me an 1" short of the bricks. Bummer.
Fireplace Pilot Light Goes Out Kirkwa HVAC 1 11-24-2014 12:41 PM
Does the NEC prohibit running two 14/3 cables through a 3/4" hole in a firebreak? pmclough Electrical 13 08-15-2014 12:16 PM
NM-12 cables in crawl space and NEC code joemc3 Electrical 20 03-11-2014 06:07 PM
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 12:37 PM
Running electricity to fireplace. Clutchcargo Electrical 6 12-01-2007 10:47 PM
