RSJ Too Short, Help What To Do? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-16-2017, 05:07 PM   #1
Rewards Points: 2
RSJ too short, help what to do?
So hands up, I've made a monumental f**k up...
Installing my first RSJ and all was going well until I realised it was too short.
It's a 152x152x37 and should be 4280mm long, however when I ordered I put 4028mm so I'm exactly 200mm short and yes I know I'm an idiot!
Anyway, I need to resolve it so my question is can I have it extended in any way by welding the missing 200mm onto the end? Would building regs approve this?
If so any idea what it would cost to get a fabricator out to do it?
Or am I just better off writing it off as a big mistake (and lesson) and buying a new one? It was around 250.
Is it likely that the steel firm will buy it back?
Thanks in advance...
markymark74 is offline   Reply With Quote
Old 09-16-2017, 06:25 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,526
Re: RSJ too short, help what to do?
For all the people here that don't use metric.
4280mm =14 feet
200 mm = 7.8 inches
I don't see why a certified welder couldn't do a penetration weld and add the 8 inches. Maybe a plate across the joint after the weld for reinforcing. I have no idea of the cost or if it would be allowed.
Old 09-16-2017, 08:24 PM   #3
Conservitum Americum
cee3peeoh's Avatar
Rewards Points: 100
Call the inspecting agency an plead insanity. No, call a structural engineer and explain the same way you did here, See what they say.
cee3peeoh is offline   Reply With Quote
Old 09-17-2017, 07:01 AM   #4
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,528
Your supplier should be able to weld it.
I had a bent beam delivered and the company said welding was no issue but I insisted on new. If I ordered it short, I would have accepted the welding offer because that would have been my fault.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Goodman furnace short cycling charlie902 HVAC 24 12-14-2017 01:36 PM
Short or bulb Startingover Electrical 7 05-21-2016 12:08 AM
Help with lighting Short angieandmatt Electrical 4 11-07-2015 03:48 PM
Furnace short cycling repman55 HVAC 12 01-21-2011 05:41 AM
Short Circuit but Breaker does not trip vino82 Electrical 6 01-29-2010 01:54 PM
