Routing Multiple Bathroom Vents Through One Roof Penetration - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-22-2016, 10:47 PM   #1
Rewards Points: 396
routing multiple bathroom vents through one roof penetration
I had a local contractor tell me they can run multiple 4 inch bathroom vent lines through this one 14 inch vent by feeding them all up to it. On the one hand, it makes sense since there is no wye, on the other hand I guess a breeze could blow it back into another vent line.
the vent in question....
http://www.homedepot.com/p/Active-Ve...1-BL/202321472
Thoughts? is it legit?
MLMIB is offline   Reply With Quote
Old 08-22-2016, 11:18 PM   #2
Msradell's Avatar
Rewards Points: 974
Re: routing multiple bathroom vents through one roof penetration
By reading the description of it, it appears it's designed for attic ventilation, not for connection to bathroom vents. Running them all into a single vent point sounds interesting but I don't believe it can comply with code requirements. You may want to check with your local AHJ before proceeding.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 08-23-2016, 11:20 AM   #3
Rewards Points: 110
I have seen ads for a dual setup, 2 baths, 1 fan, 1 outlet.
Never more than 2.
Company uses Sony vent fans and is in Sarasota (Florida).
Sent from my SAMSUNG-SM-N900A using Tapatalk
ChuckTin is offline   Reply With Quote
Old 08-23-2016, 08:57 PM   #4
Rewards Points: 1,036
Why not vent your bath fan through the soffit or wall just below the soffit? Then you dont need to penetrate the roof membrane. also if your bathrooms are not close together this just seems like unnecessary cost. Roof penetrations are not that big of a deal if they are done correctly. However, i have worked on houses where they did not allow any penetration visible from the street. My gut feeling is that someone is trying to sell you on a system that is complicated(more things that can go wrong) probably not practical and most likely more expensive for you and more profitable for them.
I have not seen a bath fan vented through the roof in a very long time.
Active Ventilation Products roof louver product line, the Pop Vent, is excellent for venting attic spaces on shingled sloped roofs.
You can get as fancy or as dumb as you want with it but in my location on new houses these are the only acceptable methods.
if you have a flat roof you may choose to go through the roof instead of the wall but you would use one of these and it will cost more.
Mingledtrash is offline   Reply With Quote
Old 08-23-2016, 10:18 PM   #5
Rewards Points: 396
I can look into venting through the wall, but most of what I have read on venting through a soffit recommends against it since there are concerns of the moisture.
http://thehtrc.com/2013/getting-deta...xhaust-venting
I have 3 bathrooms on top/next to each other and I'm trying to limit penetrations, so I was figuring 1 roof penetration was better than 3 if possible. I'd have a professional do it as I'm not comfortable doing it for the reasons you've alluded to.
if the 3 through 1 is legit I think it's my best option for the 3, the fourth one I may look into a wall vent to eliminate a roof penetration.
Old 08-23-2016, 11:01 PM   #6
AHHH in my area no on uses soffit attic venting so i see the problem. soffit attic vent + fan fan vent = problem.
the only problem i saw with your plan was it appeared to me you were using an unsealed system where you just had an attic vent and ran the bath vents up near the opening or just stuff into it with no seal. as long as the vent system is self contained all the way to open air and not just ran into your attic near the vent and you have a proper louver on each pipe to prevent one fan blowing air into another bathroom your good to go.
this ^^^ would be acceptable going through your roof as long as the main pipe is sized properly and each duct has baffle to prevent back draft and you have the proper vent on top of the roof. you will still get condensate drip in your bath though.
http://inspectapedia.com/ventilation...ct_Lengths.php.
If your trying to do something similar to this ^ but with a vent above it, its not acceptable even if the pipes are stuffed up into the 14 in vent.
Finally i found what i was looking for^ the proper way to do this. ^
http://www.ventilation-system.com/ca...room-kitchens/
Bathroom Vent Fan Exhaust Routing Problem Thunder Chicken HVAC 7 10-17-2015 08:00 PM
Hail damage to vents but not roof? KY1 Roofing/Siding 5 09-28-2012 09:21 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
Roof Turbine Vents vs. Traditional Ridge Vents. One Better? kennykenny Roofing/Siding 2 04-29-2011 10:33 PM
Roof Vents for Very Hot Second Floor somewhatsketchy Roofing/Siding 1 08-11-2010 11:54 AM
