Round Post To Square Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-19-2018, 04:31 PM   #1
Rewards Points: 4
Round post to square beam
I have found a pile of treated 9" diameter x 25' poles. I want to do a deck at 10' and an all metal shed roof at 20'. 5' in the ground. Stand them in a grid with a maximum span of 12'. Was thinking I could notch and bolt in two 2"x12"x12' sistered boards for the 'beams'. Then hang 2x8x12 joists(16oc) between them. Am I structurally sound or bouncing failing floor or weakened post from notching potential? Thanks to any structural or engineer types out there.
elrancho is offline   Reply With Quote
Old 07-19-2018, 04:45 PM   #2
retired framer
Rewards Points: 6,228
Re: Round post to square beam
You could likely just flatten the sides and use hangers.
Old 07-20-2018, 05:39 AM   #3
Rewards Points: 554
Full 9" is bigger than usual 6x6 posts used for projects like yours. 6x6 shouldn't be notched because there isn't much left. Your poles should be ok but that is my non engieer assumption. Beam must be solid across the span, no joint. All joints must rest on the poles. Beam ends should have at least 2" seat on the pocket.
carpdad is offline   Reply With Quote
beam replacement and sistering Bamboozler Building & Construction 22 06-20-2016 01:01 PM
Post to beam connection Dkaya Building & Construction 10 08-31-2014 09:58 PM
Post & beam connection liljohnny Building & Construction 6 07-10-2014 08:24 AM
Point Load - LVL Beam Install, Load Bearing Wall Zif0684 Remodeling 2 04-05-2014 08:29 PM
Moving ridge beam post brick_layer Carpentry 10 05-18-2011 11:43 PM
